A little tractor project
   / A little tractor project
I would worry that debris found its way into the engine. Do you have it turning freely. You might want to flush it out with diesel fuel - both top flush it out and help it spin freely.
It spins over fine has great compression just havnt had a chance to get it running as its not a important project, my time has been dedicated to getting my work truck back up and going as its needed bad.
Well things worked out in a awesome way.
Started with dads tractor and done aqquired another one that is more complete and runs.
   / A little tractor project #23
Glad you caught the fever. Does at least one of them run?
Both run kinda, we swapped the parts needed from the new one over to dads and it runs on fuel then dies pretty sure its sucking air into the system.The other one has a possibly bad injection pump, as it will run on ether which is how we loaded it.
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
1984 GROVE CRANE (A54607)
1984 GROVE CRANE...
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
