A Level Field
   / A Level Field #1
sunspot
Rural Birmingham, AL
Ford 3910 86'
I have old pasture land that is a bit hard to mow due to dips and holes and a few rises. I recently ran a two bottom plow through about a half acre and after a week, I ran a 20 X 20 Tandem Disc Harrow over it.
It's still not the level field I'm looking for. I want land that I can drive a normal car over it at speed without breaking anything on the car or my neck.
I've been eyeing Spike/Drag Harrows wondering it that would help smooth thing out.
So the question to the members here is what to use? Chain or Spike. Ridged or Flexable?
I was thinking of a Spike Tooth Drag Harrow with a rigid frame vs. flexible.
Here are some models I found on a web search.
Leinbachs
Per the web site, they make this in house.
Martens
McFarlane
What is the difference between open end and closed end?
Buhler
   / A Level Field #2
You may also want to consider a drag of about 10 feet wide that can be angled and then do multiple passes from different directions to help smooth the ground. Disk afterwards and repeat the process till it meets your needs. A rough field is no fun.
The spiked harrows look nice. That is about all that was used in the area I grew up in. We called them diamond harrows!:D
   / A Level Field #3
I'd keep going over it with the disk. Over and over in different directions, each time decreasing the angle of the gangs. I've been amazed how good that is at leveling. That should take care of any major humps/depressions, but a drag harrow would be nice to smooth out the little rows left by the disk.
   / A Level Field #4
plow then disc then harrow. an old steel bedspring can do the harrowing if you disc it well, or a chain harrow works well.
   / A Level Field #5
They can be hard to find these days but a spring tooth drag works much better than a spike tooth for leveling ground, IMHO. They work pretty good for breaking up clods, too. My dad used both and says the springs are much better. I know the springs do a good job but I personally have no experience with a spike. All we used on the farm when I was a kid was springs. I have used a small section that I could pull with my garden tractor for years on lawn projects. Last summer I salvaged an ancient Ford 3PTH spring tooth from my neighbors fencerow. I plowed and then leveled off some reclaimed swampland with it and a roller. I could easily drive a car on it. Good luck.
   / A Level Field #6
I made a drag out of two crossties with a section of old chain link fence between the ties. I had old field with rows from soybeans to level. I tilled the dirt then ran the drag over the loose dirt and it smoothed it pretty well. I think that it would have been better if I had a roller to pack the dirt before I leveled it. I have a roller now and am going to use it when I level some more land. big dan
   / A Level Field #7
IMHO, the key to getting the ground level is length of the implement.
think: road grader vs. snowplow.
the longer the ridgid lenth of the implement, the less prone it is to sinking into the valleys and causing dips at the cutting surface.
once the surface is broken (plow, tiller, disk, whatever), i've had good luck using the front end loader in a drag type position to shave off high spots and fill low. you'll never get the same results as a grader because of the location of the wheels relative to the cutting surface, but it's better than a flexible drag that just follows the contours of the surface.
if you think about it, the best way to maximize the length of your machine is use the front end loader in combination with a back blade. set both to scrape just an inch or two off the high spots and then go at it from all different angles until you gradually get it smoothed out. this will shave high spots and fill low spots.
another way to get some advantage is use a machine with large wheels relative to the size dirt clumps you have. if you have access to a larger tractor with very large wheels, you won't have as much undulation as you drive over the plowed surface.
it takes some time, but short of renting a grader, you'll end up with a pretty smooth end result.
   / A Level Field #8
I'd build a log harrow. Find a straight lenght of oak, or something heavy, and cut it as wide as you can pull behind your tractor. I pull an 8 foot one that's 18 inches thick behind my 35hp 4wd tractor. I have a length of chain wrapped around each end of the log that I loop over my tow bar. Then I have a length of cyclone fence wrapped around the log to help smooth things out.
The disk breaks up the dirt. The more you disk the land, the softer the soil will be and the easier it will be to smooth out. The log will plow the high spots and fill the low spots. It wont move allot of dirt, but it will move some. If you have really bad areas, it will ride up over them and make the smoother, but it won't take them down. You'll need to do that with a FEL or box blade. Then go over it with the log drag.
I've been using mine for 4 years, and it's one of my favorite implements. Also my cheapest!!!!
Eddie
   / A Level Field #9
Eddie Walker and N80 summarize my experience and recommendations. My drag is a long metal pipe.
   / A Level Field
Thanks to all for the replies. I think I will try to save a few bucks and try the logs and fence method first.
If that fails, it's time to spend $ on a new toy.:D
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
UNKNOWN TANK MANIFOLD (A58216)
UNKNOWN TANK...
HUSQVARNA RIDING...
2015 JOHN DEERE 35G EXCAVATOR (A52707)
2015 JOHN DEERE...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
