A horn for my tractor
/ A horn for my tractor #1
bfletch7441
Sapulpa, OK
MX 5100
It's an MX5100. Don't need it for anything, just want to honk at folks as I go by and get peoples attention when they're helping me. I don't want an air horn or anything too outlandish, just something that works and is loud enough to hear it over the tractor. Anyone installed one before?
Ben
/ A horn for my tractor #2
I would put one of these on it. It will defiantly get peoples attention.
Wolo/12 Volts heavy duty old car Ooogah sound Fun Horn (330) | Horn | AutoZone.com
Its 114 Decibels so its a bit louder then you wanted.
Never installed one as mine has one from the factory. All you need is a self returning switch (not sure of proper name) and hook it up to the electrical system.
You could probably pick up a horn of a car at a salvage yard for cheap.
/ A horn for my tractor #3
I went to the auto parts and got a horn, relay, horn button and wired one in on my M9540. Seems that these tractors should have horns already on them as a lot of people use them to clear cows out of the way or signaling other people on the property. Of course they should have a glove box of some type on cab tractors but they don't have that either.
/ A horn for my tractor #5
How interesting, My Kioti has a horn factory installed, and I just haven't found a use for it yet! I don't have any cows!
/ A horn for my tractor #6
Works for geese too .And wifey
/ A horn for my tractor #7
Here is a genuine kubota horn.
http://www.lashleyparts.com/Kubota-Tractor-Part-33430-75950
It will sound like a piece of construction equipment.
You could also do like Gary said and get a horn at the auto parts store. If you do get a horn that does high and low tone, I can't think of what that is called.
My 4240 has one, I wish the BX did. It is handy.
/ A horn for my tractor #8
I'm surprised adding a horn is so complicated for you guys. My L45 came pre-wired for the horn. The steering wheel had a horn switch in it and the wires went right to the front of the grill with a std horn connector set already installed. I just need to add an actual horn.
ac
/ A horn for my tractor #9
The TLB's are designed for commercial use, so they have an option for a horn (I'm not positive but I believe its might be a safety requirement for commercial job sites.) However, most of the other tractors Kubota sells are primarily intended for agricultural use so they're not setup for a horn.
The good news is Kubota seems to be listening to customer demand as I know a horn is now standard on the new B50 series that I'm getting (no need to go through the trouble of retrofitting another horn.)
/ A horn for my tractor #10
Both of my tractors have a horn.. I never use it.. I just shake my bucket at them if I want something out of the way..Lou
/ A horn for my tractor #11
Horn.jpg Got this off ebay for $25 When working around people it comes in handy.
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A61568)
2022 East...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Yamaha Golf Cart (A64047)
Yamaha Golf Cart...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
2020 CATERPILLAR 262D3 SKID STEER (A62129)
2020 CATERPILLAR...
(2) UWS TRUCKBED TOOLBOXES (A62131)
(2) UWS TRUCKBED...
