A horn for my tractor
/ A horn for my tractor #1
bfletch7441
Sapulpa, OK
MX 5100
It's an MX5100. Don't need it for anything, just want to honk at folks as I go by and get peoples attention when they're helping me. I don't want an air horn or anything too outlandish, just something that works and is loud enough to hear it over the tractor. Anyone installed one before?
Ben
/ A horn for my tractor #2
I would put one of these on it. It will defiantly get peoples attention.
Wolo/12 Volts heavy duty old car Ooogah sound Fun Horn (330) | Horn | AutoZone.com
Its 114 Decibels so its a bit louder then you wanted.
Never installed one as mine has one from the factory. All you need is a self returning switch (not sure of proper name) and hook it up to the electrical system.
You could probably pick up a horn of a car at a salvage yard for cheap.
/ A horn for my tractor #3
I went to the auto parts and got a horn, relay, horn button and wired one in on my M9540. Seems that these tractors should have horns already on them as a lot of people use them to clear cows out of the way or signaling other people on the property. Of course they should have a glove box of some type on cab tractors but they don't have that either.
/ A horn for my tractor #5
How interesting, My Kioti has a horn factory installed, and I just haven't found a use for it yet! I don't have any cows!
/ A horn for my tractor #6
Works for geese too .And wifey
/ A horn for my tractor #7
Here is a genuine kubota horn.
http://www.lashleyparts.com/Kubota-Tractor-Part-33430-75950
It will sound like a piece of construction equipment.
You could also do like Gary said and get a horn at the auto parts store. If you do get a horn that does high and low tone, I can't think of what that is called.
My 4240 has one, I wish the BX did. It is handy.
/ A horn for my tractor #8
I'm surprised adding a horn is so complicated for you guys. My L45 came pre-wired for the horn. The steering wheel had a horn switch in it and the wires went right to the front of the grill with a std horn connector set already installed. I just need to add an actual horn.
ac
/ A horn for my tractor #9
The TLB's are designed for commercial use, so they have an option for a horn (I'm not positive but I believe its might be a safety requirement for commercial job sites.) However, most of the other tractors Kubota sells are primarily intended for agricultural use so they're not setup for a horn.
The good news is Kubota seems to be listening to customer demand as I know a horn is now standard on the new B50 series that I'm getting (no need to go through the trouble of retrofitting another horn.)
/ A horn for my tractor #10
Both of my tractors have a horn.. I never use it.. I just shake my bucket at them if I want something out of the way..Lou
/ A horn for my tractor #11
Horn.jpg Got this off ebay for $25 When working around people it comes in handy.
Kubota L3901HST
Kubota L3901HST
2020 John Deere 2025 R HST Tractor with Loader (A61166)
2020 John Deere...
2017 Ford F-550 3yd. Mason Dump Truck (A61568)
2017 Ford F-550...
(96) 1"X8"X10" PONDEROSA PINE BOARDS (A62131)
(96) 1"X8"X10"...
New/Unused 3 in 1 Bucket for Mini Skid Steer (A61166)
New/Unused 3 in 1...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
