A frame Hoist
/ A frame Hoist #1
truckdiagnostics
Platinum Member
Central WI
7753 bobcat
Built this A frame hoist, followed plans I found in the forum, can稚 find the post to give him credit. Works slick. Only modification I made was adding the jacks, so I can raise and lower for the different heights in the ceiling. Then I can raise it way up and tuck it in with the car lift. Steve
/ A frame Hoist #4
:thumbsup: Gooder-un!
/ A frame Hoist
The width between posts is 11'6". We went with the odd width to clear the car trailer.
Here is a scan of the print.
We followed the print verbatim, only change was the hydraulic lift jacks. Cutting the angles for the legs was a challenge and you may want to consider having someone make those cuts.
/ A frame Hoist #7
What's it rated for?
Do you remember who posted the plan?
I have two forklifts, a Deere with a loader and a Case Super 580M jibs for all. However working inside eliminates all that.
/ A frame Hoist #8
I need to build this along with a JIB for my forklift.
/ A frame Hoist
thought orignal plans came off this forum, but looked high and low and can't find it.
won't rate it not an engineer, you can work it back words as there are some new ones on the internet for sale that are the same but different
steve
/ A frame Hoist #10
I like it! Hopefully I'll be able to find this when I'm ready to build.
/ A frame Hoist #12
I like your shop! I did the same thing, with an internal pitched roof for added height for the auto lift.
6-12 outside, 3-12 inside. Got away with only 9' side walls.
/ A frame Hoist #13
/ A frame Hoist
I would add a strut at the botton, near the casters, to keep it from doing the splits.
Don't believe you need that with the size of the tube and the angle it is on there is enough material there to weld too, also went with this design just because there is no bar at the bottom. This makes it easier to roll, around the shop as you can go over the small stuff.
/ A frame Hoist
Thanks, if anyone is interested I can start a second post with the specifics on how we did it. When we built it I was on a tight budget, so we went with stock truss and over the lift we used rafters to match the roof pitch. Then with a 24" over hang we were able to get that extra foot tucked up into the soffit. We can lift a car all the way up and not hit, when I lift the suburban I have to watch.
Since we look at it from the house and it is the first thing you see when you come in the road we didn't want this monstrosity that is why we build this building the way we did.
/ A frame Hoist #16
Just saw the two 10" long horizontal pieces in the plans. I missed them in the pics. Looks like it should hold up just fine.
You can see that if they wern't there, it wouldn't be nearly as strong.
/ A frame Hoist #19
I'm interested. The HF model is just too small. Yet I need something that will lower down to fit in the shop I'm stuck with.
2018 CHEVROLET IMPALA (A66091)
2018 CHEVROLET...
2829 (A65055)
2829 (A65055)
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
2021 Ford Explorer Hybrid AWD SUV (A66738)
2021 Ford Explorer...
2003 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2003 FORD F150...
2000 STERLING LT8500 SERIES WATER TRUCK (INOPERABLE) (A67714)
2000 STERLING...
