A different steel frame method-garage
/ A different steel frame method-garage #1
davo727
What do you all think about this guys method- Used a Long steel bar joist at the peak of his building? I like it and am considering using it since I can get a salvaged 44 to 50 ft joist locally for cheap.
inside pic
/ A different steel frame method-garage #3
You won't have to worry about termites!
How is it cost wise for the snow load you need?
No snow here, But I will use a much shallower roof pitch to catch less wind and a bunch of 8 inch purlins from the center joist to the walls. Then 2 by 4s every 4 feet cross ways on top of the purlins, then foam insulation board and then the steel roofing.
Here is that guys page on the shop build A Garage is Born
Looks like a pretty low dollar amount spent on the building, though he has some good toys inside.
