A Catastrophe of sorts.
   / A Catastrophe of sorts. #14
Be careful on the portable crimpers. The bench type hydraulic crimpers do a far superior job. 2-3K PSI is nothing to take a chance on.
Ron
I'm sure not all crimpers are created equal. Definitely be wary of the electrician/hvac type or ones intended for low pressure hose. But this weatherhead t-460-2 unit with its 10k psi cylinder was made for this task, uses the same fittings and caliper readings as the bench top version. I've been in enough hydraulic shops to see this unit w electric pump doing commercial hoses.
   / A Catastrophe of sorts. #15
I have both a Gates 601 and a 4-20 crimper. Both work very well. I buy my hose and fittings from Discount Hydraulic Hose
Ken
Giyi 59" Vibratory Roller (A57149)
Giyi 59" Vibratory...
TPM RM900SB All Terrain Remote Controlled Weed and Brush Mower (New/Unused) (A59225)
TPM RM900SB All...
2199 (A58376)
2199 (A58376)
2019 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A52709)
2019 CATERPILLAR...
2288 (A58376)
2288 (A58376)
26120 (A56859)
26120 (A56859)
