A Catastrophe of sorts.
   / A Catastrophe of sorts. #14
Be careful on the portable crimpers. The bench type hydraulic crimpers do a far superior job. 2-3K PSI is nothing to take a chance on.
Ron
I'm sure not all crimpers are created equal. Definitely be wary of the electrician/hvac type or ones intended for low pressure hose. But this weatherhead t-460-2 unit with its 10k psi cylinder was made for this task, uses the same fittings and caliper readings as the bench top version. I've been in enough hydraulic shops to see this unit w electric pump doing commercial hoses.
   / A Catastrophe of sorts. #15
I have both a Gates 601 and a 4-20 crimper. Both work very well. I buy my hose and fittings from Discount Hydraulic Hose
Ken
(1) HD 20ft Free Standing Corral Panel (A57453)
(1) HD 20ft Free...
183 (A52705)
183 (A52705)
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
Enmark Z Spray (A53316)
Enmark Z Spray...
Black Galvanized Steel Fencing Kit (A55758)
Black Galvanized...
