A/C not engaging
/ A/C not engaging #1
Orchardman
Hi there
my apologies if this has been covered in previous threads but im in a bit of a pickle. I have a Landini Rex 100 GT and have been experiencing A/C issues.
When I bought the tractor, I was under the impression that the A/C worked but the compressor wouldn't hold a vacuum. When I pulled a vacuum and put some R-134a in it, everything ran smoothly and I got cold air but of course all the coolant leaked out (You could see bubbles on the compressor itself). I argued with the company that sold it to me and they agreed to send me a replacement compressor. I also went ahead and ordered a new receiver/drier complete with a pressure switch. Before I installed the compressor, I cleaned the system thoroughly as I could, re-installed the new drier, switch, and compressor and pulled a nice long vacuum to rid the system of any moisture.
When I put R-134a into the system, the clutch doesn't engage, even though the filler gauge lists the system as being fully charged and I see movement in the sight glass. I didn't put too much refrigerant in im sure of that.
I can jump the compressor and when I do, the pressure on the low side drops from the upper 30s to close to 10 or less, even close to zero.
Does anybody have a general method of ruling out possible failing points on A/C systems that they could lend to me? This tractor seems to have multiple electrical issues with it so I can't really rule anything out.
Kind Regards
Mike
/ A/C not engaging #2
Try jumpering the pressure switch and see if the compressor will engage. Sounds like you do not have enough Freon in the system.
Low pressure is related to ambient temperature the system is running at. For 90 degrees the low side should be 45 - 50 psi and the high side 250 -270 psi
/ A/C not engaging #3
While not completely familiar with the Landini tractor, I am familiar with AC systems. You said that you installed a new drier with a pressure switch. I do know that there are different pressure switches for different operations. Sometimes the pressure switch is placed on the high side of the system and will prevent current to clutch unless a specific pressure is in the system-- prevents system from operation in case of a lost or low charge ( low pressure cut out). Sometimes the pressure switch is installed to prevent compressor operation in case of excess high pressure ( high pressure cut out). Sometimes the switch can perform both functions ( HPCO and LPCO-- called a binary switch). There is even a trinary switch that combines a binary operation for system protection and an auxiliary actuation circuit for an additional/accessory fan on the condenser. If you can locate a leak finder (Yokagawa, TIF or similar for R-134A) use it to look for leaks. Since you said the compressor had bubbles coming out of it, I am assuming you meant around the shell seams. That would indicate possible over pressure during operation -- possible causes being a clogged or restricted condenser, loose drive belt for fan, bent fan, loss of insulation/seals around the condenser radiator area, etc. You may want to try jumping the switch and checking the charge level in the system with the tractor running on high blower at idle. The pressures listed by Zebrafive above look about right. Total charge for the system should be about 32 oz max. Good rule of thumb is that the temperature drop across the evaporator should be 20-30 deg. Anything greater, is great. Anything less could mean a leaking heat shut off valve or bypass air of a blend door. I am not sure that your unit has a blend door- most automotive systems do. Equipment systems usually use a water control valve to shut off the heater coolant when operating in AC mode. Again, I am not completely familiar with your system but have had my fair share of AC system experiences.
/ A/C not engaging
Thanks for all the responses. I have the gauges and I will look at the PSI on the low and high sides like mentioned above. I forgot to mention that the compressor is brand new as is the receiver drier. That was when I played squeaky wheel with the company that sold me the tractor. The pressure switch is on the drier unit and is has a low and high cutout.
With the suggestion to jump the pressure switch and measure pressure, this is a dumb question but just jumping the compressor will accomplish the same thing right? just don't want to be wrong with that. Are the pressures listed above for when the compressor is engaged or idle? I imagine engaged b/c the highside probably won't read if its not compressing but just letting my green show. Thanks again for all the help.
/ A/C not engaging #5
I agree with Z5 that more freon is required. Jumpering across at the pressure switches or compressor accomplishes the same thing to check freon charge. The pressure's that Z5 gave are with compressor engaged. With compressor at idle the gauges will equalize at about 150 psi each.
/ A/C not engaging #6
Did you weigh in your charge?
/ A/C not engaging #7
Pressures are with compressor running. Only reason I suggested jumpering the pressure switch was you said in your original post that you were not sure if other electrical issues were the cause of the compressor not engaging. If jumpering the pressure switch lets the compressor engage it would rule out other electrical problems. So yes, just jumpering the compressor will get it running to check pressures/add Freon.
/ A/C not engaging #8
One other thing; did your new compressor come with oil preinstalled? Did they tell you how much oil the system should have?
/ A/C not engaging
Sorry I got off track there. Okay, to answer some questions. I haven't weighed my charge, I have been using 12 oz cans from the auto store. It did come pre-oiled and I turned the compressor a few times before I engaged it so it wouldn't lock up on me.
I took my pressures this time while I tripped the compressor and this is what happened. At rest, the low side is sitting around 59-60 and the high side sits to about 100. When I engage the compressor, the low side goes down to nothing and the high side goes up to about 150. I don't even get a moderate amount of cooling going on.
It sounds like I still have a low system charge overall. so I should add more R-134a until both sides equal out at about 150 psi at rest? I just don't want to add too much and blow something up.
/ A/C not engaging #10
G'day add some more charge with the comp running until you see 2-220 on the high side and see what happens you may have a blocked TX valve though
Oh and jumping the pressure switch will tell you if the rest of the elecs including the thermostat is working correctly as the comp should cycle on and off as it gets to temp
Jon
/ A/C not engaging #11
I think somethings plugged on the inside(orifice/expansion valve) because with compressor off(at rest) the pressures should equalize no matter how much Freon is in the system.
/ A/C not engaging
Jon
Hi Jon
Thanks for the reply, I imagine that I should put more charge in until it hits 2-220, but I guess I am afraid that the low side might get too high. From what I can see from charts posted about ambient tems/low side pressure. My pressure for the low side is already pretty high.
Also, im not up on my slang, what is a TX valve?
/ A/C not engaging #13
They are referring to the expansion valve. Your symptoms indicate it it either plugged or stuck shut. Sounds like you need to replace it.
/ A/C not engaging
A plugged valve makes sense. Everything was left open for a long time while I waited for the new compressor. Stupid question, but the expansion valve is probably inside my cab, right?
And while I am sure it is in bad form to complain about a company, to those of you who live in Washington, steer clear of Blueline Mfg. Happy to take your money, but you are outta luck after that.
/ A/C not engaging #15
Going back to your inital post - the comment about cleaning out the system as best you could should have raised a red flag. If you feel the need to clean the system while the compressor is out of the circuit, the expansion valve(yes, it's in the cab, at the inlet to the evaporator) should be removed and the system flushed in both directions. The high pressure lines from compressor outlet through the condensor and all lines(minus drier)up to the expansion valve fitting. Through the evaporator and suction line down to compressor inlet. Once the sytem is clean, then install the exp valve, drier, and connect the compressor. Any fittings removed should recieve new O rings(if they are O ring fittings), and then begin the evacuation and charging process.
/ A/C not engaging #16
Orchardman
After having system left open for a while did you pump it down with an evacuation pump to remove air/moisture? If not the moisture could be freezing causing blockage.
/ A/C not engaging #17
You don't charge a system not running and say it's full unless you have a scale. Without a scale you are under or overcharged. There is no gage that says full for static charge.
2003 Freightliner FS65 Converted School Bus (A64194)
2003 Freightliner...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2020 Mack Anthem...
2016 Jeep Grand Cherokee 4X4 SUV (A64557)
2016 Jeep Grand...
Swict 78in Bucket Skid Steer Attachment (A64553)
Swict 78in Bucket...
