A backup camera for $50!!!!!!!!!!!
/ A backup camera for $50!!!!!!!!!!! #511
never did install mine either. Hard to find enough down time with the tractor to pull the roof and figure out all the wiring.
/ A backup camera for $50!!!!!!!!!!! #514
My contribution to the epic 7 year running camera thread...
I finally installed my forward and rear camera system! 1080 P resolution, wired cameras, and 7" monitor.
I read about too many complaints about wireless video lag, so I went wired. I think it's actually easier to install since the video cables carry the power to the cameras. One point at the monitor for the two power connections, run video cables, mount cameras and monitor. Voila. I should add that it wasn't $50. I spent about $200.
/ A backup camera for $50!!!!!!!!!!! #515
I'd thought that I'd posted pictures but apparently I had not. So... Here is what I came up with for a movable front camera mount, one that can protect the camera and take a beating (needs to provide some give). It's a section of a PTO shaft cover with a spray can lid fitted in the front with a hole to receive the camera (in theory the camera will snap-fit in) I need to perfect this- can't use any drill or saw to make the hole in that plastic as it's too brittle- need to cut with heat. Attaching to the tractor is accomplished via a couple of super magnets; one on the inside of the shaft guard and one on the outside (they pinch and hold the inner cap from rotating/moving- can kind of see this in the picture taken on the backside); an additional piece of plastic goes between the outside magnet and whatever you're going to attach to (otherwise the super magnet is going to stick like crazy and scratch paint). I struggle with placement in order to SEE when I'm using my pallet forks. I've found that moving the camera to the brush guard's vertical side bracket allow me to angle the camera up or down for best angle: display on monitor then needs to be rotated to match reality.
Looking from the front:
From the rear:
Yes, no front grill guard. I know I'll curse myself, but with over 1,800 hrs operating two tractors in really nasty stuff I have not really damaged anything at the front: I need a top hood guard, though, as I've managed to dent the tops of BOTH hoods!
/ A backup camera for $50!!!!!!!!!!! #516
Most backup camera systems are controlled by a switch that monitors the transmission indicator switch and operates only when you're backing up .Will your camera setup stand up to continuous service?
/ A backup camera for $50!!!!!!!!!!! #517
I'll answer that.
My installation has run as much as 3 hours continuously and shown no ill effects.
Also using a strong magnet as your mounting method is a very practical method.
Recently there has been a large selection to be found, many with holes for attaching your camera,
In fact I even magnet mounted my display using a magnet.
Also all my LED floods, spot and beacon also use magnets.
IMHO magnet mounting is the way to go.
Snag a light on a limb, simply fish it back and re attach with no, or rare, damage.
Also easy to re position for optimal effects.
/ A backup camera for $50!!!!!!!!!!! #519
Yeah, I have run mine for up to 6-7 hours a day, 2-3 days a week, for about 7 years now. For crappy cheap camera and screen, it's done well. I think I was all in for well under $50. This is one of the best threads of all time on TBN.
/ A backup camera for $50!!!!!!!!!!! #520
Would love to figure out a way to set one up on my open station tractor for use when blowing snow. Keeping my head in a forward position with a helmet on will keep me warm and dry regardless of the wind.. Well, I'll figure something out.
2005 Ford Excursion (A60352)
2005 Ford...
2021 CATERPILLAR D3 CRAWLER DOZER (A62129)
2021 CATERPILLAR...
2022 Caterpillar 289D3 (A60462)
2022 Caterpillar...
Giyi GY-CYHC Mini QA Side Shift Forks (A60463)
Giyi GY-CYHC Mini...
2016 WANCO WTSP PORTABLE ARROW BOARD (A60429)
2016 WANCO WTSP...
2020 DRAGON ESP...
