!972 Ford 2000 Hydraulics
/ !972 Ford 2000 Hydraulics #1
myford001
Green Cove Springs, Fl
74 Ford 2000
The hydraulics on my tractor just recently quit working. I rebuilt the pump(had several broken springs). Once I got it primed, it worked great. I used it for 4 hrs., no problems. Now every time it sits for several hours, apparently it's losing prime. I can loosen the allen head screw on the pump until fluid starts flowing, then it works great again. Is there a check valve somewhere, that's not working?
/ !972 Ford 2000 Hydraulics #2
While you had the pump apart, did you disassemble the nosepiece and inspect the shaft and seal? If not I suspect that's where your air/suction leak is coming from.
/ !972 Ford 2000 Hydraulics #3
did you change the orings where the hyd lines go into the pump it can suck air there also
Yes, to the first reply. I changed everything. About the O rings, I've been thinking a lot about that this evening. When I was connecting the larger tube to the pump, I had a hard time getting all the way in. I'm thinking I need to pull it out and make sure I didn't damage that o ring
/ !972 Ford 2000 Hydraulics #5
that's sounds odd you'd think if it was siphoning opening the screw would just help it do that and if you had a leak on suction line (larger tube) that pump should cavitate. doesn't hurt to check though.
Probably going to be Monday before I get a chance to look at it. Thanks for the replies. I'll keep you posted.
Caterpillar D7H Series 1 and 2 Dozer Service Manuals (A63117)
Caterpillar D7H...
2015 ISUZU NPR 4X2 16FT BOX TRUCK (A59912)
2015 ISUZU NPR 4X2...
Zero Turn Mower (A59231)
Zero Turn Mower...
(INOP) 2004 INTERNATIONAL 9400 T/A DAY CAB ROAD TRACTOR (A63291)
(INOP) 2004...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
2021 Ford Explorer AWD SUV (A61574)
2021 Ford Explorer...
