!972 Ford 2000 Hydraulics
/ !972 Ford 2000 Hydraulics #1
myford001
Green Cove Springs, Fl
74 Ford 2000
The hydraulics on my tractor just recently quit working. I rebuilt the pump(had several broken springs). Once I got it primed, it worked great. I used it for 4 hrs., no problems. Now every time it sits for several hours, apparently it's losing prime. I can loosen the allen head screw on the pump until fluid starts flowing, then it works great again. Is there a check valve somewhere, that's not working?
/ !972 Ford 2000 Hydraulics #2
While you had the pump apart, did you disassemble the nosepiece and inspect the shaft and seal? If not I suspect that's where your air/suction leak is coming from.
/ !972 Ford 2000 Hydraulics #3
did you change the orings where the hyd lines go into the pump it can suck air there also
Yes, to the first reply. I changed everything. About the O rings, I've been thinking a lot about that this evening. When I was connecting the larger tube to the pump, I had a hard time getting all the way in. I'm thinking I need to pull it out and make sure I didn't damage that o ring
/ !972 Ford 2000 Hydraulics #5
that's sounds odd you'd think if it was siphoning opening the screw would just help it do that and if you had a leak on suction line (larger tube) that pump should cavitate. doesn't hurt to check though.
Probably going to be Monday before I get a chance to look at it. Thanks for the replies. I'll keep you posted.
PORTA POTTY (A67714)
Kubota L3901HST
Kubota L3901HST
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
2015 CHEVROLET CAPRICE CAR (A66091)
2015 CHEVROLET...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
PORTA POTTY (A68842)
