970 clutch
/ 970 clutch #1
MidTNDawg
My clutch appears to be "stuck" to the pressure plate, flywheel, or both. Cannot get it to break free. I was told by a JD tech to fill the bell housing up to the inspection hole with coca cola. Anybody heard of this? Tried this?
/ 970 clutch #2
My 1070 did this once after being in a humid barn for a month. Hooked it up to a field mower (something that takes a lot of torque) and after a minute or two of running through thick grass, it was just fine. No problems since.
/ 970 clutch
Thanks. I left out part of the tech's suggestion. After allowing the coke to sit in the housing for 2-3 hours, I was to pull the tractor, in gear, to break it loose. Seems the acid in the coke does something. Thanks for the response.
/ 970 clutch #4
On the right side of the tractor there is a small vent covered by a fine screen. It is covered by the piece of plastic that wraps around below the steering column. You can see the bottom of the screen just above the loader support.
That vent is in line with the clutch disk. Remove the plastic cover, then remove the two bolts that hold the screen on. Then take a long thin butcher knife, put the point between the clutch plate and the pressure plate, and give the handle a bump with your hand while someone (or a 2x4) is holding the clutch pedal down.
It worked for me. I had tried jarring it loose by running into a dirt pile, etc., but I couldn't believe how easily it came free with the knife blade.
/ 970 clutch
Well, thanks. I will try this idea first.
/ 970 clutch
TedLaRue - GREAT INFO - On my 970 the hole is larger, 4 bolts hold the screen on, and it took almost nothing to break it loose. I did not "drive" anything in. Rather I used a screwdriver and it took maybe 6 oz. of pressure to unstick the clutch. Amazing when you consoder the way I jerked the trator by sudden acceleration and jamming the brakes on yesterday. BTW, I git it into gear by starting the engine and rolling downhill while "jamming" it into gear. Anyway, great help. Thank you.
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
New/Unused Landhonor 24in Semi-Automatic Tire Changer (A65583)
New/Unused...
2017 Volkswagon CC Sport Sedan (A64557)
2017 Volkswagon CC...
2022 EZ-GO ELITE...
