'97 F150 Trailer Connector
/ '97 F150 Trailer Connector #1
BB_TX
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
\'97 F150 Trailer Connector
Anyone have a schematic/wiring diagram for or know anything about how the connnector is wired for a factory installed trailer towing package. My brake lights/turn lights work on my truck but not to the trailer connector. They were a little flaky for a while. Now they have quit. The tail lights work fine. I suspect there is a separate relay for the truck lights vs the trailer lights and that the relay has failed. But I don't know where to start looking without a schematic.
/ '97 F150 Trailer Connector #2
Re: \'97 F150 Trailer Connector
A lot of the times the Service people at a Dealership will help You get the information You need. I have even had some that would make copies and give to me on certain things.
Just a Suggestion.....Good Luck with It.
/ '97 F150 Trailer Connector #5
Your owners manual (if you have one) will tell you if one of the relays in the Power Distribution Box under the hood is for your trailer lights. That is where they're located for the 99-03. Simple little plug in part if thats what the problem is.
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
2001 Sterling Single Axle Dump Truck (A62613)
2001 Sterling...
Vegetable Sprayer (A60462)
Vegetable Sprayer...
2021 Sol Grand Design BK390 Camper (A62613)
2021 Sol Grand...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
2011 Ford F750 Dump Truck (A62613)
2011 Ford F750...
