'97 F150 Trailer Connector
/ '97 F150 Trailer Connector #1
BB_TX
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
\'97 F150 Trailer Connector
Anyone have a schematic/wiring diagram for or know anything about how the connnector is wired for a factory installed trailer towing package. My brake lights/turn lights work on my truck but not to the trailer connector. They were a little flaky for a while. Now they have quit. The tail lights work fine. I suspect there is a separate relay for the truck lights vs the trailer lights and that the relay has failed. But I don't know where to start looking without a schematic.
/ '97 F150 Trailer Connector #2
Re: \'97 F150 Trailer Connector
A lot of the times the Service people at a Dealership will help You get the information You need. I have even had some that would make copies and give to me on certain things.
Just a Suggestion.....Good Luck with It.
/ '97 F150 Trailer Connector #5
Your owners manual (if you have one) will tell you if one of the relays in the Power Distribution Box under the hood is for your trailer lights. That is where they're located for the 99-03. Simple little plug in part if thats what the problem is.
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2004 International 4300 Fuel & Lube Truck 593775 (A62613)
2004 International...
1062 (A63291)
1062 (A63291)
Kubota Diesel Engine - Pump Takeout (Skid Mounted) (A63689)
Kubota Diesel...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
