950 power beyond?
/ 950 power beyond? #1
Harry in Ky
Elite Member
Winchester Ky
Allis Chalmers ED 40
Does anyone know if Deere or any aftermarket suppliers offer a power beyond block for an early serial number 950? It would go in place of the CH11905 cover plate listed in the parts diagram?
Also where is the most commonly used port for a sump return? I was thinking about the port occupied by a pipe plug in the left side cover for the suction screen.
/ 950 power beyond? #2
Where is CH11905?
What does your machine have on it? A FEL? MFWD? Power steering?
My machine is parked at my mothers, but give me some clues Iand I can look at mine and hopefully help you out.
But to answer your question without elaboration, PB should be an easy do.
/ 950 power beyond?
Thanks for the response. No loader, no power steering, no 4WD. I'm not asking how to do it, just asking for information on a possible source for the block.
/ 950 power beyond?
I'm looking to replace item 15 in the diagram.
/ 950 power beyond? #6
I've typically not heard it called a "power beyond block", but I know what you're talking about. We would get them from Great Bend or Woods where we got the loader and valve kits from. We've also had blocks machined locally if it was an oddball tractor that nobody offered a kit for.
I've seen guys simply drill and thread a hole in the cover plate to feed their valve. It's screwy that way because you have to dead end the 3 point to get any flow to the valve, but it is definitely a cheap way to go.
/ 950 power beyond?
I'm well aware of alternative methods to achieve the desired results. Since it's not my tractor I was just hoping for a bolt on solution. By the design of the lines/parts involved it's obvious it was engineered with that in mind. I see quite a number of threads here involving hydraulic and other problems/questions on this series tractor, so I guess I never considered it an oddball tractor.
/ 950 power beyond? #8
By oddball I meant a Satoh, Zetor, etc.
Deere lists a "valve cover" that looks like what you need, but a quick google search comes up empty on inventory. #9 in the picture:
Error
/ 950 power beyond? #9
Wouldn't this serve as as a power beyond as it utilized to attach scv's? PN for parts key 9 is R67662 but it's NLA from JD
/ 950 power beyond?
That would indeed be the part in question. That's the good news. Bad news, we can't get one. I guess we could try to search out a used one, but probably better off to customize the existing part. That was my first thought to begin with, but just hoping for a simple way out.
Thanks to all.
CAT D11R Ripper Teeth (8) (A68134)
CAT D11R Ripper...
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
PALLET WELDING SUPPLIES/TOOLS (A67714)
PALLET WELDING...
2025 CATERPILLAR 255 SKID STEER (A65056)
2025 CATERPILLAR...
1999 22ft Express Trailers T/A Enclosed Cargo Trailer (A66738)
1999 22ft Express...
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
