90, 135, 175 ??? What PSI do I need?
/ 90, 135, 175 ??? What PSI do I need? #21
When you get your compressor, make sure you can easily drain the water from it. My old 20gal compressor had rusted out, even though I tried to keep it drained. Problem was, that little petcock was hard to get to, and was placed where spiders and other ickies hung out.
So, I did like my dentist... I saw him drain his compressor one day.
Before I got my new 60gal upright in place, I leaned it back, and pulled the petcock from the bottom of the tank, where it was impossible to get to. I put an elbow in it's place. I put a piece of 3/8" pipe coming off the elbow, facing towards the side where I would have access. On the end of the pipe, I placed an air nozzle. I set it where it is out of the way and won't get accidently bumped.
Now, when I finish doodling in the garage, I just put the tip of my shoe in the ari nozzle lever. Press down lightly, and blow any moisture out of the tank. Cost a whole $5 or so for the pieces.
/ 90, 135, 175 ??? What PSI do I need? #22
That's a great idea! Almost as good as an automatic drain and a lot cheaper I'm sure.
Hi again, everyone!
I have been trying to balance cost vs usefullness [as applied to my specific needs] on this compressor purchase. I had read some previous threads and made a decision pretty quick to steer clear of oil less compressors.
Bird, funny, but that link did not work for me either last night, so I edited it out of that post...then later it did work... /forums/images/graemlins/confused.gif Anyway it wasn't needed as I had copied the details into the post anyway.
I took a look at the Puma unit you mentioned. It probably is a little better than the CH, but in the end the CH unit won my decision, because it has a 135 psi rating, while the Puma is 115 psi. In the past I had wished for more pressure to break free nuts with my impact wrench, so 135 seemed desirable.
Also, while I did not ask, that model was not in the catalog which offered free shipping. Maybe everything they sell has free shipping, I don't know...
I really do prefer the V type to the in-line compressors! Oh well... /forums/images/graemlins/tongue.gif
RobertN, that sounds like a great idea. I was going to pipe in a ball valve, but a push with the foot sounds like it would be much more convenient!
Looks like that compressor is on back order and may not get here for 3 weeks or so. I don't care anyway...that will give the sheet of ice on the driveway time to disappear...
Thanks again for all the help!
/ 90, 135, 175 ??? What PSI do I need? #24
Your post got me to thinking how it had been a while since I had drained my 60 gal upright for the same reasons you mentioned. So today I decided to take care of that and I was surprised to get about a quart of water out of the tank. Didn't expect that much. I am going to install a drain like you described so I won’t have an excuse to ignore it any longer. /forums/images/graemlins/cool.gif
/ 90, 135, 175 ??? What PSI do I need? #25
I hope You have better Luck with Yours than I did .After 18 months of limited use it began to trip a 20 amp breaker intermittently.
I have had it to two motor repair shops that said nothing was wrong other than a 33 amp in rush on start up.
They have a capacitor start/run General Electric motor. and will cost to the tune of $191.00 from Sears as it is an OEM motor because of the shaft design for direct drive!
The run capacitor was manufactured by Cambridge Capacitors , which is made in England with no distributors in the USA.
A close(in physical size) will cost You close to $40.00 and the only place I could find one was from Allied Electronics in Fort Worth, Texas
It will be my last one ever From Sears!
/ 90, 135, 175 ??? What PSI do I need? #26
If I was going to buy a Craftsman air compressor it would be like the one in the following link, not the direct drive oil-free type.
Craftsman
But instead of buying this air compressor from Sears, I would buy the same thing (Porter Cable) elsewhere for considerably less money. Looks like Sears has set the pressure cutoff up to 150psi verses 135psi on the PC.
Porter Cable
/ 90, 135, 175 ??? What PSI do I need? #27
Bill:
For my shop and my air tools I bought (2) CH 5 horsepower 20 gallon horizontal compressors at TSC (Tough S**t Charlie's). I re-wired the motors for 220 volt and then set the cut off switches so that one compressor cuts out a little ahead of the other one. If I am using a die grinder or a mist cooling unit, only one compressor runs because of the reduced cfm demand. If I am using the sandblaster or my 3/4" impact, both compressors will kick in.
I like the small horizontal compressor as they fit right under my workbench whereas the large vertical type take up precious room in the shop. Actually, most of the time, I only power one compressor.
I also plumbed my shop air in plastic. I used schedule 60 solvent weld tubing, 3/4" for the main runs and 1/2" for the feeder lines. The nice thing about plastic is that you get no rust or scale from inside the pipe. An added plus is it's about 1/4 the cost of black iron pipe and you don't have to thread it.
I made a manifold for the 2 compressors from 3/4" plastic and used 1 wire hydraulic hose to join the compressors to the manifold. About the only point I get any condensation is at the compressor drains. I have water separators in front of my in-line oilers and I never notice any water in them.
I bough both compressors on sale at TSC about 2 years ago. They are single stage 2 cylinder oil bath units and I believe I paid about $600.00 for them. The complete shop with all lines, electrical, oilers and separators was about $1500.00.
The 5 horsepower CH units are rated at 10CFM each. That's 20 total CFM for both. That's more than you'd get from a large vertical unit and if you need a lesser CFM, you run one and slow your electric meter down somewhat. /forums/images/graemlins/grin.gif
I think 90 psi., would be fine for spray painting or an air greaser as well as an air hose blower. Most air tools like my IR impact wrench are rated at 135psi., maximum My die grinder is rated at 90psi., and my mist coolers are rated at 90psi., too. 175 psi., would be for a commercial unit where you's encounter long runs of supply lines and many branch lines. Remember, the more you raise the psi from ambient, the more heat you generate. Consequently, the more moisture you generate too. I'd think, for home shop use, 135 psi., would be ideal. I considered going to 175 psi., but at that compression, I would have needed a chiller unit to remove that air borne moisture or the moisture would have destroyed my air tools.
/ 90, 135, 175 ??? What PSI do I need? #28
You do know that Devilbiss makes them for Porter-Cable and Sears don't You?
I think It all depends on the company Specs. as to what You get /forums/images/graemlins/grin.gif
/ 90, 135, 175 ??? What PSI do I need? #29
</font><font color="blue" class="small">( You do know that Devilbiss makes them for Porter-Cable and Sears don't You?
I think It all depends on the company Specs. as to what You get /forums/images/graemlins/grin.gif )</font>
Yes, now that you mention it, I do recall coming across that fact when I was looking to buy my compressor. The Craftsman and the Porter-Cable are the only ones I ever found in my area made by them though. They used to be pretty much identical, but they are slightly different now. At the time Lowe’s carried the PC and it was $100 cheaper than the Craftsman plus they had 10% off for using their credit card. I do like this compressor. /forums/images/graemlins/smile.gif
/ 90, 135, 175 ??? What PSI do I need? #30
Yes and the larger models of Porter-Cable are nice to!
Tractor Supply handles Ingersoll-Rand Now and not at a bad Price if You want a single-stage Compressor.
Henro Check Out TSC............I think You will be surprised at what they offer now. /forums/images/graemlins/grin.gif
Daryl,
I guess I could have gone with a couple smaller units...sounds like a good solution...but the $429, delivered, no sales tax for that Campbell Hausfield was too good for my needs to pass up.
But now I do have a plan if I need more cfm in the future!
Tomnky,
I had checked out the units at TSC last month but at the time I was considering the IR V-twin and they did not have that one on hand. I think they did have the CH units, but was thinking at a higher level at the time and did not really check them out with much interest.
Still...free delivery and no tax is hard to beat. I have a van, rather than a pickup, so dragging one of these vertical units home would have been a pain.
I will report back on the pains of the delivery after I get the thing off the truck! Don't expect any probems though, as I have palet forks that clamp on my bucket.
/ 90, 135, 175 ??? What PSI do I need? #32
Henro:
After the decision is made it's the right one!
Egon
/ 90, 135, 175 ??? What PSI do I need? #33
Sounds good to me!!
/ 90, 135, 175 ??? What PSI do I need? #34
Try a HVAC supply for that capacitor. Grainger is another good bet.
/ 90, 135, 175 ??? What PSI do I need? #35
They did not have anything the physical size.It is a 40 microfarad at 370vac the capacitor mounts inside the end-cap , so without jury-rigging It (Allied is the only place I could find it) I had to get it there.
It will be here Wednesday. /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif It is 1.75 inches in diameter and 4 inches long. The replacement is 1/2 inch shorter but 1/8 inch larger in diameter and I think it can squeeze inside to my best guesstimation.
Thanks for the Suggestion. btw: She is a round One /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
/ 90, 135, 175 ??? What PSI do I need? #36
Just for the record they sent a size different than what was stated in their catalog online .So now it is the Scrap Pile for the Sears and on with the Hunt for a New Compressor!
I am looking hard at the Porter-Cable with an 80 gallon tank(two-stage) or the Ingersoll -Rand from TSC with the 80 gallon tank(single stage).
The IR is $130.00 cheaper but no delivery /forums/images/graemlins/frown.gif
Just an update in case anyone is interested! /forums/images/graemlins/crazy.gif
Well, I still don't have the air compressor from Harbor Freight Tools.
As a matter of fact, I just got a post card saying they are going to cancel the order, as required by the FTC Mail Order Rule if I don't sign the post card and tell them how long I am willing to wait.
Which I am not going to do, because I think it may just delay the cancellation of the order another month. I would bet someone is selling first at higher prices elsewhere. HF may have a deal with the manufacturer to take excess production, that only appears when other vendors are not selling/ordering at expected levels. Back to ground zero here.
Yesterday I saw a Coleman 60 gallon 135 PSI Max compressor at Costco for around $370. It has an aluminum pump housing with cast iron cylinders.
This is the same one, at the Northern Tool Site (I think)
I think I may just buy this one. I don't have heavy use needs at my end at the present. My old 20 gallon compressor for the most part worked pretty good, except occasionally being short on CFM.
Anyone have one of these? Any opinions on durability of the aluminum/cast Iron sleeve combination?
Thanks for your help! /forums/images/graemlins/smile.gif
/ 90, 135, 175 ??? What PSI do I need? #38
Bill,
Since you're going to be up this way this weekend, you could make the extra 30 to 45 minute drive toward my house and stop at the local Harbor Freight store and pick up the air compressor in person, if they still have one at the store.
Their number is 330-779-3020, if you want to check to see if they have it in stock. I've also found that sometimes the store prices are lower than the catalog prices.
/ 90, 135, 175 ??? What PSI do I need? #39
<font color="blue"> Bill,
Their number is 330-779-3020, if you want to check to see if they have it in stock. I've also found that sometimes the store prices are lower than the catalog prices. </font>
An update for the western PA gang, if anyone ever needs to make a trip to Harbor Freight-
From the I-79 & I-80 interchange, go west on I-80 about 33 miles and exit at exit 223 (this is state route 46). Head south on route 46 for about 1.5 miles to Mahoning Ave. There is a BP gas station on the right hand side. Turn right. Approximately 1/2 mile on the right hand side is Austintown Plaza and the Harbor Freight store.
From Pgh, taking the PA and Ohio turnpikes (I-76), You want to exit at the I-80 interchange (I believe it's exit 218). This exit also gives you an option to exit on County Road 18 (Mahoning Ave). Exiting on Mahoning Ave, go east about 2 miles and Austintown Plaza will be on the left hand side of the road, directly across from Wally World and Sears Hardware.
It's funny that sometimes their prices are lower in the store than in the catalog. Has anyone else ever found this to be true? My father-in-law drove out from Clearfield to buy the $39.99 brad nailer special advertised in the sale catalog, and ended up paying $19.99 for it. That savings covered the gas for the 2 hour drive!
Hi Andy and all,
Well, this morning I cancelled that HF order. Decided to get something NOW local, rather than wait on a promise that might not be filled for a long time.
I happend to see an IR compressor at the Tractor Supply that I stopped at after the lunch meeting on Saturday. $499, about the same specs as all the other cheaper 60 gallon units. I think I am going to buy that one. Looks a lot better than the Coleman unit being sold by Cosco and should be worth the extra $130.
Thanks for the directions to the HF store. Might take a drive up that way one of these days when I feel like browsing tools, something I can spend hours doing... /forums/images/graemlins/smile.gif
10,000 PSI AIR HYDRAULIC PUMP (A58214)
10,000 PSI AIR...
3410 (A47477)
3410 (A47477)
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2019 Chevrolet AWD Equinox SUV (A59231)
2019 Chevrolet AWD...
7050CFL (A59228)
7050CFL (A59228)
TOWABLE HYD WOOD SPLITTER (A60430)
TOWABLE HYD WOOD...
