9 hp engine popping through carb when I floor it. Will also buck and kick.
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #1
Shamus M
Ohio
Bobcat, kubota, john deere, simplicity
After 5 seconds or so it will go normal
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #2
carb jets are probably set too lean... what kind of 9 HP and year ?
It's a 91 Yamaha 4 cycl golf cart. Plug is nice gold or tan color. She will smoke white sometes under heavy load like pulling cart at full throttle. No smell and not burning oil
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #4
How many carbs does it have?
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #5
i agree.. popcorn can mean lean...
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #6
I had a truck that backfired all the time. I blamed it on an exhaust that was loose and had a bad gasket.
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #7
Yes.... and lean is hot, and hot is bad.
You will see the pipes glowing in the dark at idle (air cooled engine). I think there is a jet obstructed.
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #8
fo sho...
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #9
lookit MHP, IH cub, and allis G.. all small 4bangers all in that 9ish to 13ish range. :)
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #10
I think he meant 4 cycle.....so I deleted my post.
JOHN DEERE HPX GATOR 4x4 *NOT RUNNING* (A50324)
JOHN DEERE HPX...
HEADACHE RACK (A51248)
Lot of 2 Caterpillar Loader Tires (A51691)
Lot of 2...
30in Forks and Frame Mini Skid Steer Attachment (A51691)
30in Forks and...
Miller Curbilder, Kohler Engine (A52384)
Miller Curbilder...
