9 hp engine popping through carb when I floor it. Will also buck and kick.
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #1
Shamus M
Ohio
Bobcat, kubota, john deere, simplicity
After 5 seconds or so it will go normal
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #2
carb jets are probably set too lean... what kind of 9 HP and year ?
It's a 91 Yamaha 4 cycl golf cart. Plug is nice gold or tan color. She will smoke white sometes under heavy load like pulling cart at full throttle. No smell and not burning oil
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #4
How many carbs does it have?
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #5
i agree.. popcorn can mean lean...
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #6
I had a truck that backfired all the time. I blamed it on an exhaust that was loose and had a bad gasket.
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #7
Yes.... and lean is hot, and hot is bad.
You will see the pipes glowing in the dark at idle (air cooled engine). I think there is a jet obstructed.
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #8
fo sho...
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #9
lookit MHP, IH cub, and allis G.. all small 4bangers all in that 9ish to 13ish range. :)
   / 9 hp engine popping through carb when I floor it. Will also buck and kick. #10
I think he meant 4 cycle.....so I deleted my post.
2020 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
2018 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2018 Allmand...
2025 K2030 UNUSED Metal Garage (A53117)
2025 K2030 UNUSED...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A53473)
2016 RAM 5500...
