8N STEERING QUESTION
   / 8N STEERING QUESTION #1
rzacc
Greetings all. My 8n steerig is very tight and hard to turn. Does anyone have any suggestions?? I tried to loosten the adjusters, but the inner screw only turns about 1/2 turn. Im not sure if I should push it, or not, or if it will do anything anyway. Thanks in advance.
Ron Z
   / 8N STEERING QUESTION #3
I'm assuming you have the late steeing box with sector adjust studs.
did you loosen the locknuts before you tried to turn the studs?
in any event.. if it is already tight. adjusting the studs off will just add backlash.. I'm not sure that's what you want.
jack the front up and see if there is any rise inthe steeirng wheel when you turn... also does it turn freely up? many times spindle bushings will wear and cause hard steeing.
if the thrust bearings are gone and someone honked down on the sector adjusters that will do it to.
post back.
soundguy
MILWAUKEE 52" HIGH CAPACITY MOBILE WORKBENCH (A51248)
MILWAUKEE 52" HIGH...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
RIDGID K-400 POWERED DRAIN CLEANER (A51248)
RIDGID K-400...
2010 KMC 3376 Peanut Combine (A53472)
2010 KMC 3376...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A53472)
Michelin CARGOXBIB...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
