8N Ford Tractor Trailer
/ 8N Ford Tractor Trailer #1
Dacus
Advice, please, on a suitable trailer to haul a 1949 8N Ford tractor behind a 1997 Toyota Tacoma six cylinder straight drive 4wd equipped with a towing package. Thanks!
/ 8N Ford Tractor Trailer #2
It has a listed weight of 2410 to 4043 lbs. if that helps. I would guess the upper end of the spectrum is with calcium in the tires and weights. Take a look at the videos on safe tractor loading if you haven't already.
/ 8N Ford Tractor Trailer #3
Get yourself a tandem axle, 7k capacity equipment trailer. Electric brakes on one, or both axles, and an electronic brake controller in the cab of the Toyota.
Make sure you have a frame-mounted Class 3 or 4 reciever hitch, not simply a hitch ball added to the step bumper...
/ 8N Ford Tractor Trailer #4
I haul my co workers 8N with loaded tires and would guess it is right at 4,000#. I use my 18' 7,000# car hauler behind my 1/2 ton V8 Titan with no issues. I would say you can do it but you will probably need a weight distribution hitch.
All the other advise given is spot on.
Chris
Thanks to one and all. The advice seems pretty consistent and I will take it all under consideration. Might be time for a larger truck.
/ 8N Ford Tractor Trailer #6
According to my towing guide book you max tow rating is 5,000# for a 97 Taco 4x4. I think looking for a larger truck is a smart thing.
Chris
An adequate trailer and the weight of the tractor will well exceed that. That probably resolves the issue for me. One thing leads to another, right? Thanks.
/ 8N Ford Tractor Trailer #8
One has to embrace these opportunities to upgrade, they don't happen everyday!! ;)
/ 8N Ford Tractor Trailer #9
yep.. half ton truck and a 16' trailer with brakes at a minimum for those laods..
soundguy
/ 8N Ford Tractor Trailer #10
I use to tow an old Harry Ferguson about the same as an 8N.18' trailer with single axle brakes With a 1/2 ton dodge with a 360.My dodge struggled going up steep grades. It might be a little tough on that 6 cyl
/ 8N Ford Tractor Trailer #11
I still tow quite a bit with my dodge/360 1/2 ton 16' trailer and fords.. no pep on take off... but once you get there it's ok.
soundguy
/ 8N Ford Tractor Trailer #13
I have a 52 8N that I haul a few times a week with a 1/2 ton Chevy and a 16' 7000# trailer. It handles it great if it's just the tractor, but a bush hog with the tractor makes for a heavy load. I think if you just take your time you'll do ok.:thumbsup:
/ 8N Ford Tractor Trailer #14
I have a similar trailer/7500#gross weight. My 1/2 ton ford transmission eventually failed after some rigorous trailer time. Since you now have an opportunity to go with a bigger truck. I would right to a 3/4 ton pick up or better. If you expect to trailer on a regular basis,you will be happier and your truck and your nerves will last longer.
2011 Chevrolet Silverado Pickup Truck (A62613)
2011 Chevrolet...
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
MASSEY FERGUSON 7.5' DISC HARROW (A64276)
MASSEY FERGUSON...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A63689)
2021 Takeuchi...
2016 Chevrolet Silverado 1500 Pickup Truck (A64194)
2016 Chevrolet...
BRIGGS & STRATTON STORM RESPONDER GENERATOR (A64276)
BRIGGS & STRATTON...
