8N 3 point lift question ....
/ 8N 3 point lift question .... #1
Southernspeed
Central Virginia
Massey Furgeson 2850M
My hydraulics need rebuilding, it struggles to lift even moderate loads and bleeds down quickly when I shut the tractor off.
But when these are rebuilt, are they capable of lifting a 60" brush hog, 72" finish mower? What about a 60" blade?
I'm just trying to decide if it's worth rebuilding it to do these jobs or leaving it as a 'towing implement' tractor and continue using my MF2850 for the lifting work? Any insight appreciated!
/ 8N 3 point lift question .... #2
Sure it is. 8N hydraulics, when working properly, can lift ~800 pounds and it will lift all three implements you listed above. Parts are easy to get and how-to information is available at some websites and on YouTube.
/ 8N 3 point lift question .... #3
The 8N I had handled a 6' bush hog and 7' back blade and the lift was in less than good condition so after an R&R of the hydraulics it should handle your implements with ease. I would try rebuilding the lift cylinder first, it maybe all that is really needed.
Thank you gentlemen. I'll put that job on my long list of Spring farm stuff!
/ 8N 3 point lift question .... #5
As John suggested, start with the top cover and check the piston. The factory piston had 3 steel rings. Rather than a ring job on it, I would replace it with a piston from the '53-54 NAA with an o-ring and leather backup washer. It will seal better. Also take a hard look at the cam follower pin. It's supposed to be round but worn ones will have a flat spot on them. Some folks get by with pulling the pin and sticking the worn end back into the hole but I would tend to replace it on mine. The I&T service manual will walk you through making the necessary adjustments to get both draft and position control working as new.
