855 Top Link info needed
/ 855 Top Link info needed #1
855Idiot
Salt Lake City, Utah
John Deere 855
What size, type & length top link do I need for a JD 855?
I have no manual or top link.
I'd like to shop by phone but I don't know exactly what I need to ask for?
Though I'd ask before calling...
I don't know anything...:rolleyes:
Glenn
/ 855 Top Link info needed #2
Go to TSC and get a cat. 1 toplink. If it is too short they make a longer one. The regular one should work unless you have a quick hitch. If you don't have a hitch, look at Pat's easy change. JC
/ 855 Top Link info needed #4
855Idiot said:
Is it a Cat 1 or 2???
It is a cat 1. cat 2 is "usually" reserved for ~50+HP machines
P.S. have you got all the bugs worked out of the machine yet?
The bugs are more or less gone.
The starting issue was, the pedals not being aligned. I use my foot to even the pedals, then it starts.
I still need to retention the pedal springs to make them retract consistently.
The water pump still weeps and I have ordered a new one.
The fuel shut-off solenoid still won't shut off the fuel all the way...so it "diesels" when I turn the key off.
I just tap the solenoid forward to kill it. I think an adjustment will fix it.
I don't have a top-link for the 3 point.
Other than that, it's a sweet Tractor.
2014 VOLVO A40G WATER TRUCK (A62129)
2014 VOLVO A40G...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2025 MB27 27in Mixing Bucket Mini Skid Steer Attachment (A61572)
2025 MB27 27in...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2016 INTERNATIONAL PROSTAR+122 6X4 ROAD TRACTOR (A64280)
2016 INTERNATIONAL...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
