855 or 4200
/ 855 or 4200 #1
kiphorn
Central PA
TC 24D
I'm looking at purchasing a used 855 or 4200. Is there anything that sets one apart from the other? Are there any known problems with a model year of either tractor that I should avoid?
I'll be mowing 2-3 acres, plowing an 800' driveway and doing some FEL work.
Thanks for the help.
/ 855 or 4200 #2
The 4200 is about 1000 pounds heavier than the 855. If like me you don't want too much weight for mowing over a septic field on clay soils, you'd want the 855. Also, the 855 operates in smaller spaces. While they are similar in HP, the 4200 is more machine. More loader and 3 pt capability etc. I have not heard much bad to watch for on the x55 series. They were pretty well liked. (I have a 755). There have been a lot of gripes about the 4000 series, particularly a front axle problem. Search for that and you will read how to check it out. I think most of the gripes have a cure.
Kivel QA Pallet Forks (A64912)
Kivel QA Pallet...
1992 Polar 307 SS T/A Insulated Chemical Tanker Trailer (A68183)
1992 Polar 307 SS...
2010 INTERNATIONAL (INOPERABLE) DURASTAR 4300 (A67714)
2010 INTERNATIONAL...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
2008 FREIGHTLINER M2 CAB & CHASSIS (A67714)
2008 FREIGHTLINER...
Mahindra 4550-4L Loader (A64911)
Mahindra 4550-4L...
