843 bobcat
/ 843 bobcat #1
levidossAK
Alaska
Bobcat 843B
I was being foolish with my Bobcat. I was lifting with a home made 8' stinger. I had the stinger parallel with the ground. I knew it was too much weight but i lifted anyway. It lifted about a foot off the ground and then there was a big bang, then it fell to the ground. Would you suspect the problem is my cylinder? I would wait to talk to my Bobcat dealer but they won't be available until Monday and I need it on Sunday. Any ideas would be great.
/ 843 bobcat #2
Welcome to TBN. /forums/images/graemlins/cool.gif
Things will break… /forums/images/graemlins/frown.gif
I’m guessing you checked the quick tach locks. Also the cylinder and rod ends, I’ve seen them fail and break off. I would think you have something external… If not check the cylinders. You didn’t say if lift and curl functions are still working. KennyV.
/ 843 bobcat
My lift is still working but my curl is not. The curl moves close fairly freely if I press it a against something. I can push the ram in manually but it comes back out on its own.
/ 843 bobcat
The threads stripped on the end of the ram, the nut had been backing off for a while. The ram was bent so I put it on a press and ran it 3/8 past center. It's back in action.
/ 843 bobcat #6
Thanks for posting back with the problem/fix. There are a few that have a problem, then never hear about again.
I’m glad your fix was comparatively easy. (you should be able to lift a load that will lift the back of your bobcat off the ground, and not hurt the curl cylinder). KennyV.
UNUSED KJ 20'X30' METAL GARAGE (A62131)
UNUSED KJ 20'X30'...
2021 John Deere 333G Skid Steer (A63109)
2021 John Deere...
2018 FORD F450 XL 4x4 CREWCAB 5K LB SERVICE CRANE (A62613)
2018 FORD F450 XL...
2023 Chevrolet Express 2500 Cargo Van (A61568)
2023 Chevrolet...
UNUSED RAYTREE RJSG30-30" TRANSVERSE STUMP GRINDER (A62131)
UNUSED RAYTREE...
2012 EAST 39' FRAMELESS DUMP TRAILER (A62130)
2012 EAST 39'...
