84” ssqa snow blade on 72” wide tractor
   / 84” ssqa snow blade on 72” wide tractor #1
Michiganguy
Southern Michigan
Kubota MX5400
Would a 84” ssqa snow blade turned 30 degrees be as wide or wider than a tractor that has a 72” wide tire track?
   / 84” ssqa snow blade on 72” wide tractor #2
Barely but yes
Thanks!
I figured there was a formula. I probably was taught it in school but it obviously wasn’t retained.
   / 84” ssqa snow blade on 72” wide tractor #4
I run a 7' ssqa plow on my 72" wide tractor. I rarely angle it at 30 degrees because wet snow starts to push the front end around, and it rolls snow fine at a much less angle.
I recently added side plates on the plow, so this season I don't angle it at all except around turns and to square up to a pile.
   / 84” ssqa snow blade on 72” wide tractor #5
This is my 96" HD Rhino rear blade. I offset and angle when blading snow. Offset because there are a couple drop-offs on my driveway. Offset keeps the tractor a little further away from the very edge. When angled my blade will cut a 76" to 78" swath for light, fluffy snow. Less for wet, heavy snow when I have to angle more.
   / 84” ssqa snow blade on 72” wide tractor #6
So you basically turned it into a snowpusher?
   / 84” ssqa snow blade on 72” wide tractor #7
I suspect You will be running over snow when angled since some snow seems to always roll back from the windrow.
   / 84” ssqa snow blade on 72” wide tractor #8
A smaller capacity, but yes. I have since added UHMW Polyethylene closing the gaps on the side plates. I plan to remove the side plates for larger snows, as I have several very long drives I plow. 6 bolts and they're off.
On edit, I should add that I fabbed this up based on the work of a TBN user that did a similar modification.
   / 84” ssqa snow blade on 72” wide tractor #9
I have a 7'-6" plow on a 6'-6" wide tractor. Same 1 foot difference you have. I run it fully angled all the time. Like dstig1 says - it's close but it works fine for me.
gg
   / 84” ssqa snow blade on 72” wide tractor #10
Adding to the above - if I put an 8 footer on there it would give me less than 3" more on each side when angled. I don't think that is enough to make any difference at all.
gg
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2021 FORD TRANSIT 250 CARGO VAN (A52576)
2021 FORD TRANSIT...
New Long Forks (A53002)
New Long Forks...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
HYSTER H50FT FORKLIFT (A52472)
HYSTER H50FT...
2008 Ford F-450 Cab and Chassis Truck (A51692)
2008 Ford F-450...
