8171 Commercial
/ 8171 Commercial #1
twodogs
Pittsburgh, PA
Kubota B7800
I am considering the purchase of an 8171 Commercial. Anybody have any experience or info on them? I am starting my research. The body looks good & it is supposed to run strong. The owner told me that the deck will need work/replaced, depending on my abilities.
Thanks in advance!
/ 8171 Commercial #2
Hi,
Well, it's a Gravely so that's a plus. :)
As with any machine it's age (produced '78 thru '87), maintenance over it's life is key.
The 8171's (all?) came with an Onan CCKA 16.5 which is a powerhouse twin engine. No longer produced, parts can be expensive, but there are many that love this engine and feel it's worth the money to keep it running. That is something to keep in mind when reviewing the tractor's condition.
Other things to look for are: Clutch condition- are they wobbly on the shaft due to neglect or abuse? The splined shafts are a point of wear if not maintained. The clutch pads are replacable.
PTO condition is one of the most important considerations as I hear it is an 8 hour intensive job to replace. Make sure it operates normally.
Steering has some adjustment in it, but again, was it lubed throughout it's life? Excessive wear causes need of replacement parts and can offset a bargain price. Still, unless the machine is totally hammered and rusted out, it's likely worth fixing anything that's wrong.
There are coveted options which should be considered in the purchase: Does it have hydraulics? Optional front or rear PTO kits? Wheel weights or weight rack? Liftable hitch? Some of these items can fetch a pretty penny by themselves.
It's pretty common to find 50" decks with holes. If it's too bad to repair, they do come available quite often.
Sorry for rambling all over the place...I'm sure there are some points I have missed that others will hopefully join in and add.
Oh, the 800's were prone to having a frame crack under your left butt cheek. Not sure if the 8000's had the same issue.
Manuals, sales brochures, and IPLs are available at oldgravelys.net
Good luck!
Tony
/ 8171 Commercial #3
The 800 series tractors had an issue with frames cracking but that was fixed in the 8000 and later tractors.
The CCKA is a keeper. While only rated at 16 hp, it will out pull a Kohler Magnum 18 hp.
It is all the little stuff that adds up after a while. Tires, seat, engine oil change, trans oil change and a battery totals to about $500.00. Then there are brakes, clutches, etc.
/ 8171 Commercial
I haven't seen the tractor yet, but I have seen pictures. It looks to be in good shape, and it runs without smoke. The owner wants $200, so I figure it is a safe buy.
2017 Freightliner M2 106 Auto Crane HC10 5 Ton Crane Service Truck (A61573)
2017 Freightliner...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
2016 Jeep Compass SUV (A64557)
2016 Jeep Compass...
Wolverine Quick Attach Tiller (A66285)
Wolverine Quick...
Beverage Truck Body (A64556)
Beverage Truck...
CATERPILLAR D3GXL CRAWLER DOZER (A65053)
CATERPILLAR D3GXL...
