8050 Branson
/ 8050 Branson #1
Wichtex
8050 Branson
Anybody had Issues with the three-point hitch not working right. Fender switch works and inside cab switch will only raise. It's not very sensitive either. All had it 3 times to fix AC and still doesn't work.
/ 8050 Branson #2
How do you have the dials set at the back of the controller?
3PT HITCH CONTROL LEVER
(Electric over hydraulic control)
To avoid personal injury, do not use one touch
switch when engaging or disengaging
the implement.
Hitch control lever can freely lift up or move down the
rear implement. It will lift up when lever is pulled back
and move down when lever is pushed forward.
One-touch lifting up/down switch can lift up to the preset
point set by upper limit control dial and move down to
position of control lever.
DRAFT CONTROL DIAL
Draft control dial allows the implement to be automatically
lifted up depending on the load on the rear implement.
It will operate with larger weight as dial is turned CW.
It will operate manually when dial is completely turned
CCW and towing power lamp is turned off in gauge
STOP/SLOW RETURN DIAL
The rate at which the 3PT link and mounted implement
will drop is controlled by turning the dial. The rate of
down varies with the setting of control and the weight of
the mounted implement. The heavier the implement, the
faster the rate of down. The lighter the implement, the
slower the rate of down.
if you turn the dial fully to the right, the hydraulic pressure
to the device raising the implement is stopped.
2016 Mobility Ventures MV-1 Passenger Van (A66736)
2016 Mobility...
2004 Cadillac Eagle Ultimate Hearse, Eagle Coachbuilders, Hearse Collector Special (A63689)
2004 Cadillac...
2009 CATERPILLAR CP44 PADFOOT ROLLER (A65056)
2009 CATERPILLAR...
KL480 Ventrac tiller
1999 Peterbilt 330 Truck (A66736)
1999 Peterbilt 330...
2019 FREIGHTLINER CASCADIA 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2019 FREIGHTLINER...
