8050 Branson
/ 8050 Branson #1
Wichtex
8050 Branson
Anybody had Issues with the three-point hitch not working right. Fender switch works and inside cab switch will only raise. It's not very sensitive either. All had it 3 times to fix AC and still doesn't work.
/ 8050 Branson #2
How do you have the dials set at the back of the controller?
3PT HITCH CONTROL LEVER
(Electric over hydraulic control)
To avoid personal injury, do not use one touch
switch when engaging or disengaging
the implement.
Hitch control lever can freely lift up or move down the
rear implement. It will lift up when lever is pulled back
and move down when lever is pushed forward.
One-touch lifting up/down switch can lift up to the preset
point set by upper limit control dial and move down to
position of control lever.
DRAFT CONTROL DIAL
Draft control dial allows the implement to be automatically
lifted up depending on the load on the rear implement.
It will operate with larger weight as dial is turned CW.
It will operate manually when dial is completely turned
CCW and towing power lamp is turned off in gauge
STOP/SLOW RETURN DIAL
The rate at which the 3PT link and mounted implement
will drop is controlled by turning the dial. The rate of
down varies with the setting of control and the weight of
the mounted implement. The heavier the implement, the
faster the rate of down. The lighter the implement, the
slower the rate of down.
if you turn the dial fully to the right, the hydraulic pressure
to the device raising the implement is stopped.
1500 GAL WATER TANK (A68842)
1500 GAL WATER...
2013 CHEVROLET SILVERADO 1500 (A67714)
2013 CHEVROLET...
2020 Nissan Murano SUV (A66738)
2020 Nissan Murano...
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
John Deere 4040 Tractor (A64047)
John Deere 4040...
WALK OVER LADDER (A68842)
WALK OVER LADDER...
