8' pull-type disk behind L5460, possible?
   / 8' pull-type disk behind L5460, possible? #31
Then there's something drastically wrong with your 8N. As a kid I pulled that disc with Dad's 8N over many, many, many acres. Almost always on plowed ground.
Nothing wrong with it but the tires are not loaded.
SDT
   / 8' pull-type disk behind L5460, possible? #32
This thread is a good example of what happens when you try and mix city people who buy a tractor with people who grew up around them.
Always an excuse for limitations....rather than real world experience.
Agreed.
SDT
   / 8' pull-type disk behind L5460, possible? #33
SDT
That would explain a lot. Never had a tractor on the farm without loaded tires. Even my little JD in the pic has loaded rears.
   / 8' pull-type disk behind L5460, possible? #34
What I can tell you is that no matter what type of tire you run if you pull a 10 foot disc and a 7 point chisel plow when it hasn't dried out enough, you can bog down and bottom your tractor out.....twice in one day.
   / 8' pull-type disk behind L5460, possible? #35
I rarely learn the first time either...... :cool:
   / 8' pull-type disk behind L5460, possible? #36
My neighbor has a Brown - pull behind - disk harrow. It great because I can hook up the hydraulics from my top link - raise the unit up on its wheels and motor down the road to my place. It cuts a 9' swath and weighs around 1400#. I've used it a couple times. Just gotta wait until the ground is dry. The M6040 pulls it easily. If I have to go into 4WD - LOOK OUT. I may have hit a wet spot and need to get the heck out of that immediate area.
   / 8' pull-type disk behind L5460, possible? #37
I doubt seriously it will pull it with any authority. My 4060 grand L struggles pulling a 7 foot land plane up any kinda grade in M
I am curious to see how it acts with my 6 foot HD tuffline . I'm not optimistic.
40 or 50 horsepower in a hydro tractor is nothing even close to a gear drive.
No need for some people to act like his BIG 50 HORSE tractor is gonna walk off with a 8 foot disk.
In reality he's equal to about a 25 horse in pulling power.
   / 8' pull-type disk behind L5460, possible? #38
That's an interesting comment, one I'll take at face value. Then I looked up the Nebraska test for the old Cockshutt 30 of my youth that hauled an 8' IH model 37 transport disc all over 50+ acres of corn ground for years. 27 drawbar hp.
   / 8' pull-type disk behind L5460, possible? #39
Well take it for whatever value you want. As soon as it gets dry I'll hook my disk up and give it a try and post up some videos on YT so anybody that's interested can see for themselves.
From my experience it a big difference in hydro and gear drive when it comes to pulling power.
Will it pull it ? I'm sure it will . Will it pull it good enough to be worth while ? I doubt it.
I also doubt the tractor will hold up pulling a 8ft disk for very long.
   / 8' pull-type disk behind L5460, possible? #40
Hey you threw the number out there, I didn't. A 50 horse MFD tractor should be capable of putting 50% of that power on the ground through any transmission worth building. Remember to link us to your videos.
2013 Ford F150 (A55973)
2013 Ford F150...
PENDING SELLER CONFIRMATIONS (A57880)
PENDING SELLER...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
2018 Ford Fusion (A56859)
2018 Ford Fusion...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
2013 Vermeer V800G T/A Towable Vacuum Trailer (A56857)
2013 Vermeer V800G...
