8' cutter options & opinions
   / 8' cutter options & opinions #1
dstacy
Houston & our ranch in Centerville, TX
a few green & yellow ones
Ok I know there are a million opinions out there but help me any way.
I have a Deere 5093E so horsepower isn't an issue. I'm looking for an 8' twin spindle cutter, not a 7 footer or a 10 footer, etc., etc.
90% of the time I'll be cutting grass but like all of us do on occasion I'll find a few saplings and brush that will need to go away and I'll be too lazy to get off the tractor and cut them down :)
So I'm looking at the Deere MX8 but can't decide if I should get the 3 point version or the semi-mount that uses the lower arms and a hydro cylinder on the rear wheels.
I really don't know the other manufacturers so I'd sure appreciate knowing the model numbers of comparable units and your thoughts on 3 point vs semi-mount.
Thanks in advance.
   / 8' cutter options & opinions #2
I have a full 3pt mount mx 10 on my 5083E and while its a tad heavy and I could really lug the motor down on a gopher hill. Never had a semi-mount so I can't really compare for you. I will say that without the loader on I can really get to bouncing so the 10 footer is prolly to big and an 8 would be just right. Really nice thing about the 3pt is I can pick it up and set it down onto a large bush that has a thick stump but not much else. Also, I can reach out into a soft spot/ditch and knock the weeds down.
I wondered about that very issue. It is a tough call. The semi-mount will follow the terrain better but there are advantages to being able to pick up a 3 point cutter just like you said.
   / 8' cutter options & opinions #4
Compare price with a LandPride RCR2596.
I find the 3PH more maneuverable. If cutting an area that was just flat sweeps back and forth it wouldn't really matter the mount.
Think which you like more, a 3PH disc or a pull disc. Same general idea.
   / 8' cutter options & opinions #5
My cutting is around ditches, waterways, roadsides and timber trails. I prefer mounted. With a hydraulic top link I also gain clearance if backing into an unknown area or crossing a deep ditch. I carry a 10' JD1008. I also carry 840lbs of suitcase weights on the front of the tractor.
   / 8' cutter options & opinions #6
I do not own one, so just my 2 cents............I like the looks of a Rhino TR96
   / 8' cutter options & opinions #7
Thats probably the best way I have ever heard them comapred that translated very easily and made perfect sense. WEll done.
2014 Ford F-550 (A55973)
2014 Ford F-550...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
HUSQVARNA RIDING...
2019 CATERPILLAR 239D3 SKID STEER (A60429)
2019 CATERPILLAR...
John Deere 855DXUV Gator (A57148)
John Deere 855DXUV...
