Tires 790 tire pressure
/ 790 tire pressure #1
scdawg
I've searched the forum but can't find the answer. My 790 has 75% liquid filled 11.2-24 r1 tires. I inflated them to 17 psi. I'm wondering if that's too much pressure. There doesn't appear to be a lot of tread contacting the ground. What pressure do ya'll run?
/ 790 tire pressure #2
Park on a hard surface, and adjust air pressure til all the tread contacts the ground.
/ 790 tire pressure #3
I had filled R4 tires and ran about 15 psi in mine which worked fine, but other then a bit of rear grading, I never did much ground engaging work.
I suggest you drop it down to about 12-14 psi and see how that does for you.
1978 Fruehaue Chipper Trailer (A62613)
1978 Fruehaue...
2016 FORD F-250 XL SUPER DUTY (INOPERABLE ) (A65643)
2016 FORD F-250 XL...
2023 SANY SY225C EXCAVATOR (A63276)
2023 SANY SY225C...
10000LBS Two Post Auto Lift (A64194)
10000LBS Two Post...
201 FORD F-150 LARIAT TRUCK (A65054)
201 FORD F-150...
2015 Peterbilt 320 T/A McNeilus Front Loader Garbage Truck (A64556)
2015 Peterbilt 320...
