790 Question?
/ 790 Question? #1
rjp444us
Rocky Hill CT.
JD 790 Satoh Beaver
Here is the Question for all 790 owners.
How long will the hydraulics keep the tractor off the ground and not creep!! Mine goes up and almost immediately it is back on the ground.Especially the backhoe?
/ 790 Question? #2
rjp, mine is pretty much the same. I was working it pretty hard (backhoe) this weekend and it was hot, sunny and humid. After a while I was beginning to think something was wrong as it would not stay up through my first bite of dirt. No external leaks at the stabilizers so it must be internal. I'll have to check my manuals for acceptable leakdown rates.
Normally, I set the loader down first then the stabilizers. A couple of times, working close to the trench I set the stabilizers down first. It seems to raise higher and stay up better when I do that for some reason.
Note I said no external leaks on the stabilizers. I do have some weapage on one of the swing cylinders. I've heard these are pretty susceptible due to the location. How are yours holding up?
/forums/images/graemlins/smile.gif
/ 790 Question?
The swing cylinders were both leaking but the dealer changed them. I think that the leak rate is totally unacceptable and I am going to have a word with the dealer...
/ 790 Question? #4
<font color="blue">I think that the leak rate is totally unacceptable and I am going to have a word with the dealer </font>
Let me know what you find out /forums/images/graemlins/smile.gif
/ 790 Question? #5
Richard, here are the drop rates from the "Horicon Hydraulic Attachments Technical Manual" for the #7 backhoe:
Internal valve leakage -
Stabilizer circuit - 0.73 cu. in./min. max
Lift circuit (with relief and check) - 1.34 cu. in./min. max
Lift cylinder drop rate - .57 in./min max from transport position
Stabilizer cylinder drop rate - .34 in./min max from transport
Stabilizer cylinder retract rate - .23 in./min max from working position
Not sure if this helps you or not but at least you'll have some knowledge in talking to your dealer /forums/images/graemlins/smile.gif
2018 BRADLEY MACHINE MINI VAC TRAILER (A67714)
2018 BRADLEY...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A67714)
GENERAC MOBILE...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2005 Bobcat B950 Hydraulic Breaker Skid Steer Attachment (A66734)
2005 Bobcat B950...
2006 FORD E-350 CARGO VAN (A66091)
2006 FORD E-350...
CATERPILLAR D1 CRAWLER DOZER (A65053)
CATERPILLAR D1...
