786 wiring problem
/ 786 wiring problem #1
crbailey
Browerville mn
new holland tc45
Turn signals flashers and Horn quit at same time any ideas out there
/ 786 wiring problem #2
What have You done to check it out?Fuses? corrosion in connectors?
Checked all the fuse's, tested horn button, power to and from the horn button, try to chase wires but tractor gas been repainted so my color choices are red red or red not sure why the flashers and Horn would be tied together
/ 786 wiring problem #4
------------ not sure why the flashers and Horn would be tied together
They might share the same ground wire.
Do a continuity test on the ground side of the circuit.
/ 786 wiring problem #5
Xfaxman is right.Could be a feedback issue.Check grounds.I once had a vehicle that when you pushed the window button for the left door the right door window would work.Turned out to be a bad ground
/ 786 wiring problem #6
Checked all the fuse's, tested horn button, power to and from the horn button, ------------------
Did you have power at the horn?
Another possibility is a mouse ate two wires.
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2022 EZ-GO ELITE...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
213078 (A64276)
213078 (A64276)
2012 Addco DH250-FM Towable Solar Message Board (A64553)
2012 Addco...
