786 wiring problem
/ 786 wiring problem #1
crbailey
Browerville mn
new holland tc45
Turn signals flashers and Horn quit at same time any ideas out there
/ 786 wiring problem #2
What have You done to check it out?Fuses? corrosion in connectors?
Checked all the fuse's, tested horn button, power to and from the horn button, try to chase wires but tractor gas been repainted so my color choices are red red or red not sure why the flashers and Horn would be tied together
/ 786 wiring problem #4
------------ not sure why the flashers and Horn would be tied together
They might share the same ground wire.
Do a continuity test on the ground side of the circuit.
/ 786 wiring problem #5
Xfaxman is right.Could be a feedback issue.Check grounds.I once had a vehicle that when you pushed the window button for the left door the right door window would work.Turned out to be a bad ground
/ 786 wiring problem #6
Checked all the fuse's, tested horn button, power to and from the horn button, ------------------
Did you have power at the horn?
Another possibility is a mouse ate two wires.
2019 Ford F-250 4x4 Crew Cab Pickup Truck (A64194)
2019 Ford F-250...
2005 Ford F-150 Ext Cab Pickup Truck (A64556)
2005 Ford F-150...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
FORD 3 BOTTOM PLOW (A64278)
FORD 3 BOTTOM PLOW...
2018 CATERPILLAR 320 EXCAVATOR (A65053)
2018 CATERPILLAR...
2013 DODGE RAM 2500 CREW CAB TRUCK (A64280)
2013 DODGE RAM...
