786 wiring problem
/ 786 wiring problem #1
crbailey
Browerville mn
new holland tc45
Turn signals flashers and Horn quit at same time any ideas out there
/ 786 wiring problem #2
What have You done to check it out?Fuses? corrosion in connectors?
Checked all the fuse's, tested horn button, power to and from the horn button, try to chase wires but tractor gas been repainted so my color choices are red red or red not sure why the flashers and Horn would be tied together
/ 786 wiring problem #4
------------ not sure why the flashers and Horn would be tied together
They might share the same ground wire.
Do a continuity test on the ground side of the circuit.
/ 786 wiring problem #5
Xfaxman is right.Could be a feedback issue.Check grounds.I once had a vehicle that when you pushed the window button for the left door the right door window would work.Turned out to be a bad ground
/ 786 wiring problem #6
Checked all the fuse's, tested horn button, power to and from the horn button, ------------------
Did you have power at the horn?
Another possibility is a mouse ate two wires.
2022 EZ-GO ELITE...
2017 Nissan Altima 4 door (A63689)
2017 Nissan Altima...
Chevrolet Metal Tailgate Metal Decorative Sign (A64557)
Chevrolet Metal...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
2005 KENWORTH T800 T/A 6X4 DAY CAB TRUCK TRACTOR (A67147)
2005 KENWORTH T800...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
