7711 Fuel leak behind injector pump
   / 7711 Fuel leak behind injector pump #1
SteveS42240
Ford 4000
A friend has a Zetor 7711 that has a fuel leak behind the fuel injector. It appears to be coming from a hose behind the injector pump. I need some help on how to change that hose. Will the injector pump have to be removed or can the hose be changed with the pump in place?
Thank you.
Steve
   / 7711 Fuel leak behind injector pump #2
Is it a return line? You have a picture?
   / 7711 Fuel leak behind injector pump #3
Def. need a picture..
You say its an "injector" line but mention the pump??
It is a rubber fuel hose, not a metal line. I will take a picture and post it when I can.
I said it is a HOSE behind the pump. It appears to be a flexible rubber fuel hose that is looped behind the pump. I did not have adequate lighting and tools to investigate further. I will take pics and post them with more information in a few days.
   / 7711 Fuel leak behind injector pump #6
Probably the fuel return line back to the tank. Does it connect to a metal line that comes off of all of the injectors? If so you could just add a new line and run it at about the same height and angle of the original hose and just disconnect the old one from the fitting at the injector and leave in there.
53ft trailer Vin IUY VS2532 7M0152 01 VS2RA (A51694)
53ft trailer Vin...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
JOHN DEERE 648R LOT NUMBER 108 (A53084)
JOHN DEERE 648R...
