7711 Fuel leak behind injector pump
   / 7711 Fuel leak behind injector pump #1
SteveS42240
Member
Ford 4000
A friend has a Zetor 7711 that has a fuel leak behind the fuel injector. It appears to be coming from a hose behind the injector pump. I need some help on how to change that hose. Will the injector pump have to be removed or can the hose be changed with the pump in place?
Thank you.
Steve
   / 7711 Fuel leak behind injector pump #2
Is it a return line? You have a picture?
   / 7711 Fuel leak behind injector pump #3
Def. need a picture..
You say its an "injector" line but mention the pump??
It is a rubber fuel hose, not a metal line. I will take a picture and post it when I can.
I said it is a HOSE behind the pump. It appears to be a flexible rubber fuel hose that is looped behind the pump. I did not have adequate lighting and tools to investigate further. I will take pics and post them with more information in a few days.
   / 7711 Fuel leak behind injector pump #6
Probably the fuel return line back to the tank. Does it connect to a metal line that comes off of all of the injectors? If so you could just add a new line and run it at about the same height and angle of the original hose and just disconnect the old one from the fitting at the injector and leave in there.
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A56129)
2022 BRAZ0 40FT...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
Power Horse 7000 Generator (A54865)
Power Horse 7000...
Metal Plate Container Side Plate (A53425)
Metal Plate...
OKI C6900 Printers (A53425)
OKI C6900 Printers...
