7711 Fuel leak behind injector pump
   / 7711 Fuel leak behind injector pump #1
SteveS42240
Member
Ford 4000
A friend has a Zetor 7711 that has a fuel leak behind the fuel injector. It appears to be coming from a hose behind the injector pump. I need some help on how to change that hose. Will the injector pump have to be removed or can the hose be changed with the pump in place?
Thank you.
Steve
   / 7711 Fuel leak behind injector pump #2
Is it a return line? You have a picture?
   / 7711 Fuel leak behind injector pump #3
Def. need a picture..
You say its an "injector" line but mention the pump??
It is a rubber fuel hose, not a metal line. I will take a picture and post it when I can.
I said it is a HOSE behind the pump. It appears to be a flexible rubber fuel hose that is looped behind the pump. I did not have adequate lighting and tools to investigate further. I will take pics and post them with more information in a few days.
   / 7711 Fuel leak behind injector pump #6
Probably the fuel return line back to the tank. Does it connect to a metal line that comes off of all of the injectors? If so you could just add a new line and run it at about the same height and angle of the original hose and just disconnect the old one from the fitting at the injector and leave in there.
10ft Pallet Fork Extensions (A54865)
10ft Pallet Fork...
King Kutter TG72 Rotary Tiller Tractor Attachment (A54811)
King Kutter TG72...
2012 CHANDLER 130 BBL STEEL VACUUM TRAILER (A53843)
2012 CHANDLER 130...
2024 John Deere 872GP Articulated Motor Grader with GPS Package (A52377)
2024 John Deere...
2011 Kubota KX080-3 Midi Excavator (A53421)
2011 Kubota...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
