7710 ford tractor draft lever
/ 7710 ford tractor draft lever #1
jburrow
lafayette tn
ford 7710
how is the draft lever utilized on a 7710 ford tractor? i know it works in conjunction with the lift arms but have never used it.
/ 7710 ford tractor draft lever #2
When in draft mode, there is feedback through the top link or the lower lift arms. When a change in drag force occurs due to a change in soil type, the increased or decreased draft causes the control system raise or lower the ground enagaing implement (plow). I believe the higher the draft lever is the less change it takes to cause the control to be active. I don't any plowing so I might not have this quite right but if it isn't correct someone will challenge it.
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
PALLET OF 15 4X8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4X8...
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
10 Safety Systems Barricades (A59317)
10 Safety Systems...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
