7710 ford tractor draft lever
   / 7710 ford tractor draft lever #1
jburrow
lafayette tn
ford 7710
how is the draft lever utilized on a 7710 ford tractor? i know it works in conjunction with the lift arms but have never used it.
   / 7710 ford tractor draft lever #2
When in draft mode, there is feedback through the top link or the lower lift arms. When a change in drag force occurs due to a change in soil type, the increased or decreased draft causes the control system raise or lower the ground enagaing implement (plow). I believe the higher the draft lever is the less change it takes to cause the control to be active. I don't any plowing so I might not have this quite right but if it isn't correct someone will challenge it.
2018 COLOMBO TM LOT NUMBER 184 (A53084)
2018 COLOMBO TM...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
Homemade Flatbed Tilt Trailer (A50322)
Homemade Flatbed...
UNUSED CFG INDUSTRIAL SA-FT HYD FORKS (A51248)
UNUSED CFG...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2000 Sterling L9513 Winch Truck (A53472)
2000 Sterling...
