770 step
/ 770 step #1
dlyle
White Hall, AR
John Deere 770
Looking for a step for our 770. The wife Is a little short in the stirrup! Didn't see one on the parts site but could have missed it. Any part numbers or ideas?
/ 770 step #2
Might look at the steps on some other tractors to see if they can be bolted to yours.
Or fashion one with some angle iron and plate. What is the platform height now? and what do you want the step height to be to get to the platform?
/ 770 step
Right now the 770 is at the farm a little over 3.5 hrs away so I can't measure the height. It is a 2wd with Ag tires and the step up is about 6in too tall for the missus.
Was hoping maybe a step for the 790 or more current replacement tractor would work. I don't actually have a torch or welder yet.
/ 770 step #4
Get some 3/8" thick x 2" wide flat bar from your local machine shop. They can bend it in an appropriate shape for a step and bolt that into place. All you'll need us a drill and some wrenches.
/ 770 step #5
Or some nice heavy rubber material to support a lower step. That way you can go as low as you want and not have to worry about clearence issues. Would be similar to say a lot of lower combine steps.
/ 770 step #6
Step from a 790 is part AM880256 $57.86. I'll bet it will go on, maybe have to drill some mounting holes, or might find they are already there. I would try it :thumbsup:
Have you looked on JDparts yet?
/ 770 step
Thanks for the good suggestions. And thanks for the part number. I can't imagine the 790 step not fitting since everything is so similar between the 770 and 790.
/ 770 step #8
Wait before you build something until your MMM deck is in place. With the deck in the full up position it will give you an idea how to build a step. This is what I did with my JD855............ The second time...........
Good luck
/ 770 step #9
the 790 step will go on real easy . I did one once , think I had to drill two holes but the foot rest is the same otherwise as the 790. much nicer than home made.
/ 770 step
I ordered the step Friday and should have it next week. Thanks guys it really does look good in your pictures and should be an easy install. Anything to make the Wife happy, right?
/ 770 step #12
When you pick up the step at the JD parts counter, remember to have them grab you (2) screws (M8-25; 19M7867) and (2) nuts (M8; 14M7273). They don't automatically come with the step.
2019 PETERBILT PB337 LUBE TRUCK (A63276)
2019 PETERBILT...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2018 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 VOLVO VNL 6X4...
Cattle Feeder (A65640)
Pair of 26in. 8 Bolt Combine Rims (A65640)
Pair of 26in. 8...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
