770 PTO locked up
   / 770 PTO locked up #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Second post. Everything in neutral, nothing attached to the PTO, engage PTO you can only rotate it by hand about 1/8 inch and fire it up & it wants to kill the engine if you slowly let out the clutch. So, what now?
Thanks for any suggestions
   / 770 PTO locked up #2
I'm pretty sure it doesn't have a PTO brake, so it's not that.
What's the history?
Last time tractor used?
Last time PTO used?
Any previous issues?
How many hours?
Storage of tractor?
   / 770 PTO locked up #3
   / 770 PTO locked up #4
It's two stage. Single position lever PTO engagement. Also optional front PTO. Sliding Gear dry clutch transmission. YANMAR built.
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
2006 iDrive...
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
2025 IR IRMC 8D UNUSED Massage Chair (A53117)
2025 IR IRMC 8D...
CAT Skid Steer (A50322)
CAT Skid Steer...
