770 PTO locked up
   / 770 PTO locked up #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Second post. Everything in neutral, nothing attached to the PTO, engage PTO you can only rotate it by hand about 1/8 inch and fire it up & it wants to kill the engine if you slowly let out the clutch. So, what now?
Thanks for any suggestions
   / 770 PTO locked up #2
I'm pretty sure it doesn't have a PTO brake, so it's not that.
What's the history?
Last time tractor used?
Last time PTO used?
Any previous issues?
How many hours?
Storage of tractor?
   / 770 PTO locked up #3
   / 770 PTO locked up #4
It's two stage. Single position lever PTO engagement. Also optional front PTO. Sliding Gear dry clutch transmission. YANMAR built.
2006 Ford F-550 4x4 Altec TA37M 37FT Bucket Truck (A51692)
2006 Ford F-550...
2003 Club Car DS Electric Cart (A51694)
2003 Club Car DS...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51691)
2008 Ford F-750...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A51692)
2012 Crane Carrier...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
