7520
Rambelinman
Mahindra 7520
I have a 7520 4 -wheel drive I bought new in 06. It now has 590 hours. It started to run rough so I thought it may be the filters, replaced but did not help. It will not idle below 1500 rpms without dying sounds just like it has a little miss and the engine pulls down fast when even trying to pick up the bucket. Noticed the injecter pump was hot to the touch even after a few minuites of running. Oh and when I give it full throtle it winds up slowly but does not govern it self at the redline, any ideals what may be wrong with it?
You may have a suction leak in the fuel line. What filters did you change?
larry
/ 7520
Both of the fuel, thanks I will check that out.
Check the air filter. They can collapse and choke intake if they get really dirty.
larry
/ 7520
Did that, a service teck said to check the banjo fitting on the pump for trash inside or a bad fitting, still hopefull not the injecter pump,
Not likely at that low of hrs. Also look for a pinched fuel line. That has happened to me.
larry
/ 7520
Pulled air filters, checked fuel lines, even pulled lines from tank, removed banjo fittings, still does not run right, guess time to get a mechanic to look at it, thank you Larry, I can't think of anything else to check, but the two selonoids get hot, pulled the one easy to get to no trash in it.
2016 Ford F-250 Knapheide Service Truck (A64194)
2016 Ford F-250...
2023 John Deere 333G High Flow Compact Track Loader Skid Steer (A64553)
2023 John Deere...
2008 Chrysler Sebring Sedan (A64194)
2008 Chrysler...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
2020 CATERPILLAR D5K2 LGP CRAWLER DOZER (A65053)
2020 CATERPILLAR...
2015 International ProStar T/A Wet Kit Day Cab Truck Tractor (A64556)
2015 International...
