7520
Rambelinman
Mahindra 7520
I have a 7520 4 -wheel drive I bought new in 06. It now has 590 hours. It started to run rough so I thought it may be the filters, replaced but did not help. It will not idle below 1500 rpms without dying sounds just like it has a little miss and the engine pulls down fast when even trying to pick up the bucket. Noticed the injecter pump was hot to the touch even after a few minuites of running. Oh and when I give it full throtle it winds up slowly but does not govern it self at the redline, any ideals what may be wrong with it?
You may have a suction leak in the fuel line. What filters did you change?
larry
/ 7520
Both of the fuel, thanks I will check that out.
Check the air filter. They can collapse and choke intake if they get really dirty.
larry
/ 7520
Did that, a service teck said to check the banjo fitting on the pump for trash inside or a bad fitting, still hopefull not the injecter pump,
Not likely at that low of hrs. Also look for a pinched fuel line. That has happened to me.
larry
/ 7520
Pulled air filters, checked fuel lines, even pulled lines from tank, removed banjo fittings, still does not run right, guess time to get a mechanic to look at it, thank you Larry, I can't think of anything else to check, but the two selonoids get hot, pulled the one easy to get to no trash in it.
2007 Toro Z-Master 72in. Zero Turn Commercial Mower (A64553)
2007 Toro Z-Master...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
John Deere 700 H Dozer (A62679)
John Deere 700 H...
520/85R46 MICHELIN TIRE (A64278)
520/85R46 MICHELIN...
2017 Maserati Ghibli Sedan (A64557)
2017 Maserati...
1995 Peterbilt 379 Tri-Axle Dump Truck (A61573)
1995 Peterbilt 379...
