7500 vs 2410
/ 7500 vs 2410 #1
Westbilly
SC
2410 HST FEL LA352
Is the 2410 worth $1500 more than the 7500? You get 4/2 more HP, position control, 110 lbs. weight. Does that make it 1500 worth more capable.
/ 7500 vs 2410 #2
Westbilly,
It's a marginal call IMO. The engine in the 2410 isn't all that much stronger than the 7500, and they are pretty much the same frame. If you want a stronger/bigger tractor, I'd look at the 2710 or 2910, both of which are on a bigger frame and have a distinct increase in power.
The GlueGuy
/ 7500 vs 2410 #3
I went through the same dilemma about three months ago; The same differences you pointed out are the reason I went with the 2410. The 27/2910 were just too big for what I was looking for, and the B7500 did not have some critical features I wanted (position control being one of them).
The B2410 is a perfect compromise. I mow about 5 acres with it and have used my FEL for more things that I originally anticipated. The power has been more than sufficient, and for once I can't wait to move some snow.
One thing I found is that is was real hard to find a B2410 in New Jersey when I bought mine. Apparently it's a real popular model around here, and my dealer had to get mine from Ohio.
Anyhow, regardless of your decision good luck with your choice. I can't say enough good things about Kubota products.
2014 BOBCAT T650 SKID STEER (A65053)
2014 BOBCAT T650...
GYRO TRAC GT-25 FORESTRY MULCHER (A65053)
GYRO TRAC GT-25...
2017 International WorkStar 7500 Tri-Axle Dump Truck (A64556)
2017 International...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2012 Caterpillar Warren Power Systems WCW204MH 20KW Towable Light Tower (A64194)
2012 Caterpillar...
2017 Bobcat T550 Compact Track Loader Skid Steer (A61572)
2017 Bobcat T550...
