Oil & Fuel 7500 fuel guage
/ 7500 fuel guage #1
viejo
SW MO
Kubota B7500
The fuel guage on my B7500 remains on full constantly, even after over two hours of usage. Anyone have this problem or know how to solve it. I guess I could approximate fuel usage by the hour meter, but it sure would be inconvenient. Thanks for any help.
/ 7500 fuel guage #2
call your dealer. there is a simple fix, but i cannot recall what it its. the gauge has and adjustment in the tank. took my dealer 5 min. once the new i had a problem. they are soposed to be adjusted when they build them up i think.
/ 7500 fuel guage #3
2 hours is not a lot and at what rpm's/work load,???
Mine doesn't do much untill about 3or 4 hours on full tank then drops like a ford truck!
Btw How much fuel is left in the tank after your described 2 hours??? That will tell you if in fact you have an error in your gauge!
Dean
/ 7500 fuel guage #4
I had the same problem. Found a mouse nest made of wire insulation. /forums/images/graemlins/confused.gif Removed nest and everything fine now. /forums/images/graemlins/grin.gif
/ 7500 fuel guage
Thanks everyone for the help. I'll check all this out and post again if I find the problem.
/ 7500 fuel guage #6
I can generally mow for a couple of hours on a full tank and the guage stays full the majority of the time, but it seems normal since when it gets to 3/4, 1/2 it seems correct with what's in the tank..... Never ran out, yet...but been close and the needle close to E.
2025 Fendt 943MT Vario Tractor (A63111)
2025 Fendt 943MT...
John Deere Compact Utility Tractor Operators Manual (A63117)
John Deere Compact...
Auger Drill Bit Mini Skid Steer Attachment (A61572)
Auger Drill Bit...
2009 Volkswagon Jetta Sedan (A61574)
2009 Volkswagon...
Wacker Neuson PT2 Water Pump (A59228)
Wacker Neuson PT2...
JOHN DEERE MX6 ROTARY MOWER, 3PT (A63291)
JOHN DEERE MX6...
