Oil & Fuel 7500 fuel guage
/ 7500 fuel guage #1
viejo
SW MO
Kubota B7500
The fuel guage on my B7500 remains on full constantly, even after over two hours of usage. Anyone have this problem or know how to solve it. I guess I could approximate fuel usage by the hour meter, but it sure would be inconvenient. Thanks for any help.
/ 7500 fuel guage #2
call your dealer. there is a simple fix, but i cannot recall what it its. the gauge has and adjustment in the tank. took my dealer 5 min. once the new i had a problem. they are soposed to be adjusted when they build them up i think.
/ 7500 fuel guage #3
2 hours is not a lot and at what rpm's/work load,???
Mine doesn't do much untill about 3or 4 hours on full tank then drops like a ford truck!
Btw How much fuel is left in the tank after your described 2 hours??? That will tell you if in fact you have an error in your gauge!
Dean
/ 7500 fuel guage #4
I had the same problem. Found a mouse nest made of wire insulation. /forums/images/graemlins/confused.gif Removed nest and everything fine now. /forums/images/graemlins/grin.gif
/ 7500 fuel guage
Thanks everyone for the help. I'll check all this out and post again if I find the problem.
/ 7500 fuel guage #6
I can generally mow for a couple of hours on a full tank and the guage stays full the majority of the time, but it seems normal since when it gets to 3/4, 1/2 it seems correct with what's in the tank..... Never ran out, yet...but been close and the needle close to E.
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
2026 DEVELON DX27Z-7 EXCAVATOR (A64279)
2026 DEVELON...
Case 1083 20ft Corn Head (A63118)
Case 1083 20ft...
2023 JCB S3246E ELECTIC SCISSOR LIFT (A63276)
2023 JCB S3246E...
Volvo EC220EL (A60462)
2023 CATERPILLAR 259D3 SKID STEER (A65053)
2023 CATERPILLAR...
