Loader 75 ford 4000 with 735 loader
   / 75 ford 4000 with 735 loader #1
roazo
Easton, Mo
Ford 4000
I having left front wheel bearing problem, have replaced left front bearings 4 times , the cotter key shears and nut backs off until bearings eat them selves up.Only happens on left front, I have replaced the spindle once. still having same problem, use mostly for mowing large yard, is the loader to heavy for the tractor?
   / 75 ford 4000 with 735 loader #2
did you replace the race with the bearing or only the bearing.
   / 75 ford 4000 with 735 loader #3
Is the spindle scored where the bearing sits and is there a keyed washer between the bearing and castle nut? Are you using a good quality cotter pin (not Harbor Freight) and is it the largest pin that will fit through the hole?
Yes , replaced both bearings & races
Yes to all above
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A55852)
2012 Crane Carrier...
2015 Hyundai Veloster Hatchback (A53424)
2015 Hyundai...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
